Question about Canon Office Equipment & Supplies
I have two different conon printers, ip 90 and ip 100. The two printers do not print again. The laptop (or system) recognises the presence of the printer ad communicates with it but it does not show on the printed paper. I carried out deep cleaning of the nozzles severally I still do not get result. I also did the alignment of the printers, no go result. What else can I try. I do not know if I change the catridge head holder if this may bring good result? if yes how can I purchase one each because it is not available in Nigeria. Engr. OLADOKUN STEVE. CONSTRAAD NIG. LTD email add:- constefnig@yahoo.com
worldvet
  • 859 Answers
SOURCE: not printing correctly
That doesn't make any sense either. Canon suggests that you run a deep cleaning three times. Give that a try and if you don't have success use the comment box below to ask me again.
Please remember to rate all out solutions on FixYa.
If this response has fixed your problem please rate it Fixed. If not, ask me what results you have so we can continue to work on a Fix for your problem. Use the comment box below to do this.
Thanks,
Worldvet
Posted on Jul 31, 2008
SOURCE: Deep cleaned black nozzle several times, but still splotchy printing
I have the same promblem, after changing th print head.
It priints black if I change the paper to photo paper.
Posted on Aug 04, 2008
SOURCE: printer cartridge problem
I have a 440 and have had the same problem. Of course, I have been using cartridges from Printpal, Inkgrabber, etc. that are not official Epson. I have found that it takes several cleanings and after the cartridge has been in the position for the ink to go down it will start. My last order from Printpal said to set all the cartridges in the position they are in when installed in the printer for several days prior to installation. Of course, every cleaning of the print head uses up more of your ink. You don't have much choice though.
Posted on Aug 17, 2008
dagr81
  • 59 Answers
SOURCE: no print at all on pages
dear friend
it was basically a solution
your print head needs to be replaced too
thanks
Posted on Apr 12, 2009
  • 38 Answers
SOURCE: dell 725 USB printer says catridge not present when it is
why don't you try www.247servicecenterinfo.com, they have listing of all dell service centers in india.
Posted on Jul 01, 2009
My printer Conon MG5320 is not printing ink is good feeds ok but paper comes out blank
Go the the setup menu and choose maintenance. Select "print nozzle check pattern". If nothing prints again, then select "clean". Try the check pattern again and If this does not change anything then you may have to manually clean the printheads. I will post separate instructions for this if you need.
Mar 05, 2015 | Canon Pixma Mg5320 Wireless Inkjet Photo...
Print job goes to print queue but does not print
Un install the drivers.
Connect through usb cable observe system recognised the printer?.. if recognised, reload the drivers & chk for the prints.. if not issue with formatter..
Insert net work patch cable., print configuration page., verify the ip address., load the drivers as network printer., chk for the prints., if not printing., ping ip from system... chk withnamother cable.., fotmatter issue..
Apr 04, 2014 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Can't get a Canon LBP6000 to print wirelessly on Mac system running Snow Leopard
Not all printer are compatible with Mac and this one is one of them, sorry.
Jan 12, 2014 | Canon LBP6000 Laser Printer
Printer is offline
try to ping if printer ip reachable. if yes try to connect again manually from add remove printers.
Apr 15, 2010 | HP Photosmart C7280 Laser Printer
Lexmark X644e All-In-One has link light, but does not print or ping.
If you have a router or wireless router, these routers assign a standard class C network address ie. 198.168.0.xxx or 192.168.1.xxx behind the real IP address issued by your ISP.
The reason why you cannot ping the print server could be that your computer and print server have different IP address ranges. Eg. the IP address on both the print server and the computer must contain the same first three group of numbers, only the last numbers are different.
Try configure the print server's IP address again.
Feb 12, 2010 | Lexmark X642e All-In-One Laser Printer
Hp laserjet 3055 offline when print out via networking when direct to the laptop, its working fine.......
Go to reports print configuration page it will give to netwrok configuration page check if the printer IP Address is in the same range of the IP Address of the laptopn.
If yes than check if you are able to open web browser of the printer on lkaptop using IP address of the printer if yes in laptop go to printer driver properties there go in Ports Tab and check if the Standard TCP/IP Port has IP Address of the printer of some other IP Addressif it is different IP Address than change it to the IP Addess of the printer.
Thanks and Regards.
Apr 27, 2009 | HP LaserJet 4100 Printer
Wireless Dell laptop can't 'find' HPDeskjet 5150 Printer
this printer is (as per HP specs) only connected via USB or Wlan Print server.
Check connection using USB cable and be sure Printer driver are correctly working.
Check on Router your Print server IP address (Lock it out of DHCP)
Put both PRT and PC on same home network (normally HOME or MSWORK)
Put Printer server IP address into your printer properties/port tab/ IP.
OR check if you see your printer server in your Windows network/home network
Jan 11, 2009 | Computers & Internet
COL INK VOLUME UNKNOWN MESSAGE
Something that worked for me, I opened the Conon MX310. took out both cartridges, and for 10 seconds I held the Reset. put the cartridges back in, closed the lid, and again, for another 10 seconds held the reset. SLOW seconds. this reset, ink levels recognised,, and it's working as it should be.
Regards
Shane (AKA Reef_Lex)
Jan 03, 2009 | Canon PIXMA MX310 All-In-One Printer
I have a laptop and i want to pint a page to my printer. My printer is with the main computer. i want print a pages from my laptop
set your laptop with lan in your copmputer .
set your laptop ip to computer ip with differ num in last.
then share the printer then u can give print to printer from laptop.
Oct 06, 2008 | Computers & Internet
Printer busy/or error
Sounds like your machine is using DHCP, not a static IP address?
Print your network settings from the Printer, then try to Ping from a computer on the network.
Check the Network setting of the machine, make sure it is set to a fixed (static) IP Address.
If this is the problem, you can go into your PC printers port and change the port to the reassigned IP Address of the machine.
If you reinstall the drivers then you will have this installed twice, one will work one will not, so delete it from the printers folder before you reinstall before you reinstall
Sep 28, 2007 | Sharp AR-M277 Black and White Copier
old marine
old marine
