Question about Belkin F5D8236-4 Router
The globe light is blinking. We can connect to Belkin but page not found comes up. The message that comes up says IP address does not match. We have 3 laptops, and none of them are allowing us to have access with the internet through Belkin.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
  • Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • Unplug your router and your cable or DSL modem.
  • Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1
  • Posted on Dec 29, 2010
    The globe keeps flashing orange and I can't connect to the internet because of this
    The blinking globe means that the router no longer has access to the Internet. The two most common causes are that:
    1. Your Internet connection is down, or more likely,
    2. You Internet provider has changed your IP address the the modem or router need to be reset to acquire the correct address.
    Belkin has a decent site for general troubleshooting located here.
    And a more general, but detailed troubleshooting guide can be found here.
    Jan 14, 2011 | Belkin (F5D7230-4) Router (587009)
    Cannot connect to internet. router modem and globe lights blinking amber.
    If the modem light is blinking it means that there is activity, so this is normal.
    However, the globe/internet light needs to be solid green. If it is blinking it means it is attempting to connect to the internet.
    Make sure first that the internet connection is working when directly connected to the modem. If yes, then the router might not be configured properly. To check the configuration on the router, access the setup page by using a web browser. Type 192.168.2.1 in the address bar.
    By default the password should be left empty.
    Once in the setup page of the router, go to Internet WAN. Select the connection that your ISP is using. Either, PPPOE (requires a username and password from ISP) or Dynamic, (the settings are obtained automatically from the ISP). If you are not sure, contact your ISP.
    I hope this helps!
    Mar 01, 2010 | Belkin (F5D5231-4) Router
    Belkin wired voip iad not connecting to internet with macbook
    Try opening the Network Control Panel on the MacBook. Select the TCP/IP tab, then click Advanced. Note the list of IP address numbers. Click the "Renew DHCP Lease" button and see what changed. Most likely all of them did, in particular the "Internet Gateway" and "DNS server" addresses. The first is the connection between the D-Link router and your ISP, and the other addresses are for servers that translate your web browser URLs into the IP addresses for the web sites you want to see. The Gateway and DNS server addresses have to match those in the upstream router(s). The routers must have current IP addresses assigned by the routers upstream, and any client computer must have a current address assigned by the first route upstream. You can check into this by logging in to the webpages for your routers and examining the status reports.
    Apparently one of the devices in the chain fails to obtain a new IP address when the D-Link router is powered on. I suspect it is the Belkin router. A computer with an expired DHCP lease will probably be using the Internet gateway IP address assigned to the D-Link router when it was on before (in a busy neighborhood, that address would have been re-assigned to some other household). The Windows system may be sending a request for DHCP renewal up the line, which triggers the Belkin router to ask for the same from the D-Link unit, but it may be ignoring the signal from the MacBook or not getting one.
    If the MacBook successfully gets online with a manual Renew DHCP Lease request, obtain the owner's manual for your Belkin router (find the model number, then go to the Belkin support/downloads page for that model). See what settings are available to automate the DHCP renewal process.
    Jul 10, 2017 | Belkin Computers & Internet
    Belkin Wireless G Plus MIMO router - connectivity problem
    Connect one computer directly to the DSL modem using an Ethernet cable. If your DSL service includes a static IP address, then you will need to change the TCP/IP settings on your computer to connect directly to the DSL modem. that the router or other device on your network . For these you need to follow thse steps.
    Belkin router blinking orange FIX belkin router amber light Issue
    This may help you.
    Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Belkin router signal not showing up for Wii or Laptop.
    If no signal, check router config. Use your
    internet browser to look at router's settings.
    By default the password on most Belkin routers is left blank, and the default IP address is 192.168.2.1 Check all you router's wireless settings in case disabled or incorrect. Make sure the laptop's wifi button has been toggled to OFF. Routers do die - esp the lowend ones. New wireless G router = $20 on sale.
    Jul 07, 2009 | Belkin (F5D5231-4) Router
    Lights wont turn off even if netwrk wires are unplugged..
    You'll have to hold your reset button down for atleast 10 seconds, or even more, then you'll have to reconfigure you entire connnection at address 192.168.2.1.
    However before doing that, try and power down the whole unit for a minute or so and power it back up, then go to you computer's wireless connection and renew your IP address [that's if you have automatically assigned addresses]. otherwise you might have to check that you router and computer are operating on the same page [ by this I mean, if your router is assigning automatic IP, make sure your computer is not set to use a static IP, In my years of network, this has always been problem I have experienced on some routers]
    Jun 21, 2009 | Belkin (F5D72304F5D7000) Router
    My Belkin G Wireless Router cant even get passed step 1. My lap top recieves the signal but their is no internet! Help please
    Since your unable to access internet through the router(wireless) ,& globe light is flashing--I suggest you to refresh the network list and connect to your network again still if it won't work then you need to Re- configure it. Because your Modem(cable/dsl) is working fine. Check the ip address of your computer. if its invalid then you need to do the "reset" on router (ip address should be 192.168.2... range).
    Or else you can call (toll free number) for belkin for reconfiguration
    Hope this suggestion helps for you both...
    Apr 11, 2009 | Belkin (F5D7230-4) Router (587009)
    No internet connection
    I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
    Belkin solution:
    Please follow the details given below:
    1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
    2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
    3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
    4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
    5. Please follow the instructions given below to configure the router manually:
    - Connect the phone line direct to the router, or through the filter.
    - Connect the computer to one of the LAN ports on the router.
    - Switch off the router and power it back after 5 seconds.
    - Restore the router to factory defaults by holding down the reset button on the back of the router.
    - The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
    - The corresponding lights on the router should be lit-up.
    - Check if the computer has an IP address in the range of 192.168.2.x
    - Click on `start` & click `Run`.
    - Type in `cmd` & click `ok`.
    - Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
    - If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
    Then follow the below instructions to reset IE.
    -Open Internet Explorer
    -Click on Tools -> Internet Options
    -In the General tab, click on Delete Files under Temporary Internet Files
    -Click on Clear History
    -In the Connections tab, select Never Dial A Connection and click on LAN settings
    -Uncheck all the options and click on OK
    -In the Advanced tab, click on Restore Defaults
    -Click on Apply and then OK.
    - Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
    - You should be able to access the routers set up page.
    - By default the password is blank.
    - Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
    - Save the Changes.
    Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
    Internet Status should show Connected on the top right hand corner of the web page.
    If the problem persists, please get back to us with the following information given below:
    1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
    2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
    3. ADSL broadband connection or Cable broadband connection.
    4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
    5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
    Log on to the router web interface at http://192.168.2.1
    - By default, the password is blank.
    - Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
    6. Then, check the IP address of the computer. For checking the IP address:
    - Click on start & click `Run`.
    - Type in cmd & click `ok`.
    - Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
    - The IP address should be in the range of 192.168.2.x (x=2 to 254)
    - In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
    - Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
    - Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
    Dec 28, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
    Connection
    assuming that all the configuration at wirless accesspoint is ok. see weather the card driver is installed properly. to check go to device manager>network controller> Belkinxxxxx if it is yellow, the might be device is not connected properly or the driver provided to it is not funtioning thanks arun
    Jul 19, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
    Belkin F5D8236-4 Router Logo
    144 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
