Question about Sanyo Microwave Ovens
Sanyo S15678 slightly more than one year old. Working fine but not heating.
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 29, 2010
I have an old Sanyo Microwave Model EM-FL90N which has worked great, everything works but it seems not to be heating stuff up. The manual is not of much help either. Any suggestions? Help?
Javaid,
You might want to consider replacing the microwave if it is more than 8-10 years old. Sounds like you have a magnatron that is going bad and that is what does the cooking, and to replace it could cost you almost as much as a newer microwave. Hope this helps!
Mar 24, 2016 | Sanyo Microwave Ovens
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Microwave is not heating up.
This is caused by a defective magnetron, or inverter board, "7 years old or less"
May 05, 2012 | Sanyo Microwave Ovens
Will not heat
If everything else is working fine, the magnetron is the likely problem, "heats food and is the heart of the microwave oven" if more than five years old cheaper to replace the whole item.
Mar 02, 2012 | Whirlpool Microwave Ovens
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Microwave not heating, but everything working fine
It's probably a shorted high voltage rectifier diode or magnetron.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can order Samsung parts here.
Oct 26, 2008 | Microwave Ovens
Sir, I have a 2 years old SANYO microwave with a stainless steel body. Some days ago it stops working. It is running well but does not heat up anything. I appreciate your comment and suggestion sent to my...
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked below.
You can contact Sanyo customer service and find an authorized servicer here: http://www.sanyo.com.au
Feel free to write back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. "Ed" Miller, AS-EET
prototech@usa.net † http://www.MicrowaveDisplay.com
Microwave Oven Control Panel Repair Nationwide $39.95
Jun 22, 2008 | Microwave Ovens
Microwave Ovens Logo
146 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
