Question about ASUS Computers & Internet
I just got my Eee box 1501P without OS. The Win 7 Home will not install unless I format the disk to NTFS. Apparently Win 7 doesn't do it by itself. Further I have two partitions 300GB and 20GB. Any ideas how to handle the win 7 isntallation?
    Brigadier General:
  • 8,909 Answers
The hard drive will be formatted by Win7 and should complete the instal on its own basically. I would install the OS on the 20Gb partition as that will separate your data and extra programmes but it doesn't matter. Win7 will put a crash partition on the disk automatically, usually a few Megs in size and in machine code because it is quicker and more efficient for the processor to utilize.
The drive has to be NTFS to handle file name and extensions. It will work in other formats but NTFS is easier to use.
Hope this helps.
Posted on Dec 29, 2010
Format my hp 635 laptop
Make sure you have all your data backed up
Also make sure you have your re installation disk and proper cd keys to perform a clean install.
power your unit - press F9 for boot options - insert your 7 disk into cd rom and choose boot from CD-ROM. Follow instructions provided from install disk.
Oct 18, 2014 | HEWLETT-PACKARD HP Compaq 635 156 Notebook...
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Hey please help me,does home choice laptops support windows 7 because my friends formated the hardrive please help me i realy dont know what to do,i tried installing windows 7 starter but it does&
Unless your laptop is very old, it should support Windows 7.
Did you format the disk as FAT32 or NTFS ? either of these two will do. Did Win 7 actually install correctly ? or did the install fail ?
You sure the Win 7 disk is legit ?
Oct 13, 2014 | Computers & Internet
I cant see disks in disk management how do i install operating system in my pc
You may not have created a partition on your hard disk. To install OS in your PC.
1. Insert your bootable CD in your CD/DVD-ROM Drive.
2. Press any key to boot from CD. Setup will then load the necessary files.
3. Once everything is loaded. Press "C" to create partition. You can specify the amount of disk space on your primary partition. You can also create another partition for the remaining disk space.
4. Select the partition where you want to install your Operating System then press "Enter".
5. It will prompt you to format the partition. Choose NTFS format and press Enter.
6. Once complete, it will reboot your PC several Times. If you're ask to press any key again to boot from CD...DO NOT press any KEY...Just wait for it to load. And it will continue with the setup.
7. Just follow the next steps...
Mar 21, 2011 | ASUS Eee PC 1000HEee PC1000Eee PC 901 Eee...
Install windows 7 on eeebox 1501p harddrive is
Win 7 will format it as NTFS if the drive is new enough.
The only drawback with FAT32 apart from speed is the 1256 Character limit on file names.
Dec 23, 2010 | ASUS Computers & Internet
Hi I am trying to install Windows 7 on an Asus EEE PC 900 I have installed it on USB Flashdrive but when I try to install it on the 15GB partition it states that it must be formated to NSFT,how do I do...
Install should do that for you. However assuming your current OS is on a different partition thenyour 15GB partition will be shown as a separate drive in My Computer. Right click on it and select format, in the format type select NTFS.
Aug 19, 2010 | Computers & Internet
Can I install windows on the Eee PC
Yes it is possiable to install Windows OS on the machine.
you would need an unpartitioned space on the Hard disk depending on the OS.
Win xp : 900 MB
Win Vista: 1.5 GB
Win 7 : 2 GB
you would also need a windows bootable disk.
once you have the above, change the first boot device in the bios DVD, insert the bootable CD in the CD Drive, restart the computer and follow the screen instructions
Jul 11, 2010 | ASUS Eee PC 1000H Laptop
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
211 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
