Question about Hotpoint SY21 Style Line Gas Single Oven
Hotpoint Deluxe Gas Oven BS51
When using grill, it will ignite correctly, but when using the oven the oven lights spiradically, if i hold the door switch in and light with a lighter it will work, then if i take my finger off the switch and close the door it will ignite. This happens maybe once a week and the rest of the time it lights ok.
SOURCE: hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Posted on Nov 23, 2008
  • 30 Answers
SOURCE: grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Posted on Aug 21, 2009
apart4u
  • 213 Answers
SOURCE: my hotpoint oven is not heating up but hobb and
If you have a HOTPOINTelectric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fanmotor inthe back of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from ourwebsite these can be tested with a electric meter.
To gain access to the HOTPOINTelement youwill have to remove the back plate from inside the oven. Once removed you willsee the fan and element,if you look closely at the element you will probably see a small hole burnt in it where ithas blown. Sometimes however there is no evidence of a fault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your HOTPOINTfan oven is getting warm buttakes a very long time to cook or is burning the food more on one side than theother, then you need to check if your oven fanmotor is working you will seethe blade turning fast if it is ok. if the element is heating but the fanmotor isnot blowing the heat into the oven then you need To replace the oven fanmotor is a little more expensive and a bit moreinvolved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your HOTPOINToven thermostat
4, A quite commonand easily overlooked answer is if your HOTPOINToven is not working at all ie:no heat and no fan then the chances are that someone has put the oven timer intoAUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 25, 2010
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
arepairman
  • 20 Answers
SOURCE: hotpoint sy36x grill element works fine but when
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Posted on Mar 14, 2010
How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
normal operation is to push the oven knob in and turn
pushing in sets the igniter off and turning opens the gas flow to ignite
always light an oven with the oven door open
stop s an explosion if there is a problem
down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
Aug 13, 2016 | Ovens
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
I own a Hotpoint self cleaning oven Gas - probably 1989 (only number I found was on the door - 317B6034) The ignition coil on the bottom of oven will not light up to ignite the gas tube. Locating the...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 17, 2010 | Ovens
Broken oven
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 08, 2010 | Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Grill ignition is sparking when the oven is on
Aug 21, 2009 | New World G70m Gas Double Oven
My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Jul 14, 2009 | New World G70m Gas Double Oven
Hotpoint double oven
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint dy230gx
it is normal for the grill electrode to spark as well when lighting main oven - i assume you don't mean that the grill lights - just sparks
Jun 29, 2008 | Hotpoint SY21 Style Line Gas Single Oven
Hotpoint SY21 Style Line Gas Single Oven Logo
74 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
