Question about Magic Chef Dishwashers
I have a Magic Chef CDB3100AWT dishwasher that doesn't get the dishes clean. This problem has been getting progressively worse over time. So I checked the water temperature during the wash cycle. The hot water at the kitchen sink is 133 F but the dishwasher fills with 55-62 F water. It gets up to around 68 F during the Heavy and Normal cycles and makes it to 81F half-way through the Light Wash cycle. It ends up at 94F right before the rinse cycle starts.
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
  • 848 Answers
SOURCE: Our Whirlpool KUDP01ILBS2 dishwasher isn't
Heat that is retained in the dishes is largely responsible for drying in this dishwasher. Since plastics do not retain heat very well, they will not dry as well as glasses, ceramics or metal dishes. Rinse aid must be used so that the final rinse water will sheen off of the dishes to accommodate this drying process. The heater element at the bottom of the tub is used to add heat during the drying cycle to aid in this process as well. This model of dishwasher does not have any forced air circulation system. Here are some tips that may help you resolve your drying problem:
  • Make sure that you are using rinse aid. Failure to properly use rinse aid can prevent proper drying. Adjust the amount that is dispensed if necessary. Also, check to make sure that rinse aid level decreases over time indicating that it is being dispensed properly.
  • The NORMAL WASH and POT & PANS cycles heat the final rinse water up to 140 degrees F. Use these cycles to help the drying process.
  • Do not choose the air dry option. This option cuts off the heater element during the drying process. NOTE: The heater element is not turned on during the first 6 minutes of the drying portion of the cycle.
  • Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is not working, the control will detect the lack of increase in water temperature. The dishwasher will stop and the CLEAN light will blink seven times repeatedly. The dishwasher would not be able to be used until the problem is corrected and the control is reset.
Posted on Feb 10, 2009
bigg t
  • 640 Answers
SOURCE: AM14 tank heaters--when are they energized?
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
Posted on Mar 02, 2009
SOURCE: My SHU53 only starts on 2Hr Delay and water is not getting hot
Hello- Same problem I had- It turns out that my control board (fixed once already- the solder trace on one of the three relays burned open) was junk again, but the solder trace which was fixed before was still ok, so I replaced all three relays on the board (relays are available from Digi-Key) and that fixed it!! The relays cost all of $11.00 INCLUDING SHIPPING - So if you're on a tight budget, this may work for you. Bill
Posted on May 06, 2009
I have a Magic Chef dishwasher-DU2000V and lately it has been leaving soap granules and some food deposits on dishes.
check the holes on the spray arms to see if they are clogged and not giving a good spray. Also check your owners manual to see if there is a filter to clean to give you more pressure
Dec 29, 2010 | Magic Chef 24 in. DU2000 Built-in...
Water does not go into the dish washer during the wash cyle. This is a new problem on an existing Magic chef dish washer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Magic Chef Dishwashers
Arm not turning, pumps water in and out, but no spraying the dishes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 08, 2010 | Magic Chef 24 in. DU4500 Built-in...
This is a magic chef, only a few years old. I use cascade detergent powder. the washer runs, gets water & drys but the dishes come out with a cloudy flim all over them, like the detergent is baked on
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 04, 2010 | Magic Chef CDB1500AW 24 in Builtin...
Hi, Just moved into a place with a DU4500B Magic Chef. After a cycle there is still a clump of wet soap in the main wash cup dispenser and the dishes aren't clean. Yesterday I tried putting the soap in...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 04, 2010 | Magic Chef 24 in. DU4500 Built-in...
Magic Chef DISHWASHER - mODEL du4k, STOPPED DURING drain cycle
I am assuming that the pump motor is bad, and since the unit is at least 15 years old (just guessing), we decided to wash the dishes by hand till after the holidays!!
Merry Christmas
Dec 09, 2009 | Magic Chef Dishwashers
Our dishwasher is approximately 13 years old. Today I turned it on and it did not clean the dishes. After trying to wash the dishes three times, the dishes on the bottom rack were clean but the top rack...
13 years old?!? LOL, you're lucky it turns on!!!
Pop the sprayers off and check for clogs. Otherwise, get a new one, this machine is way, way, way past its life expectancy.
Nov 20, 2009 | Magic Chef Dishwashers
Dishwashers Logo
75 people viewed this question
Top Magic Chef Dishwashers Experts
240cpa
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
