Question about IBM ThinkPad T22 2647 Notebook
ThinkPad T22 will not boot to windows
When I boot my IBM T22 a message appears 0175 - Bad CRCI stop post.
Any suggestions?
Thank you
    Genius:
  • 2,028 Answers
I've seen several T20 series with the same problem. A CRC error pertains to a chipset on the motherboard, and the only way I've found to fix a CRC error is to replace the motherboard.
Posted on Jul 07, 2008
My ibm thinkpad a20m has a problem of error 0175 CRC stop post task, it hangs at dis state, i tried to replace the cmos battery and nothing happens any other solution for this? pls help me pls?
This is a common problem for A20's. It's a bad EEPROM or a bad M/B. IBMs resolution is to replace the board. please see link.
Also found this link with some tests you can do to find out if it's the board or the EEPROM. Either way it's not a simple fix. Please click here. There is an offer for repairing the EEPROM in this link. Posting the link is purely for informational purposes. Please do not consider it an endorsement of any kind.
May 23, 2010 | IBM ThinkPad T22 2647 Notebook
ERROR 0175: Bad CRC1, stop POST task message Been using my IBM a30 laptop for some months but was surprised to get this error when i tried putting it on this message pops up ERROR 0175:BAD CRC1 STOP POST...
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
Jan 11, 2010 | IBM ThinkPad A30 Notebook
Post problem
If it beeps (which it should) means that some device did not pass post. Find your motherboard online and look up the beep codes. This should help you to discover the problem. I hope this helps!
Jul 15, 2009 | IBM ThinkPad A21m 2628 Notebook
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
Ibm t22 thinkpad laptop error 0175 crc1
Ok hm...
Sounds expensive, I'm afraid!
Here is IBM'smag-glass_10x10.gif explanation of the error codes.
What your machine is telling you is that a chip on your Motherboard is faulty and the only way to repair it is a new system board.
It is probably worth finding out how much IBM would charge you to repair it but I very much doubt you'd get much change from £500.
Mar 25, 2009 | IBM ThinkPad T22 Laptop
Error 0175: bad crc1 stop post task
It appears that your BIOS battery is nearlt flat and needs replacing.
F2 function key is the normal BIOS setup key for Thinkpad
Jan 28, 2009 | IBM ThinkPad A21m 2628 Notebook
Thinkpad A-20 will not boot
if you added new memory you need to remove it
that causes error 0175 on the thinkpad
let me know if this solved your problem
please rate me
Jan 23, 2009 | IBM ThinkPad A21m 2628 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
Cannt get normal logon screen
i think your hard disk had be dsectors
try to boot your system with win xp bootable disk
then go to trecovery console
then run
chkdsk /r
comamnd at recovery console
followthe instruction
Sep 30, 2008 | IBM ThinkPad T22 2647 Notebook
Stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply http://www.hardwareanalysis.com/content/topic/31761/
Aug 07, 2007 | IBM ThinkPad A21e 2628 Notebook
IBM ThinkPad T22 2647 Notebook Logo
268 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
