Question about HP Compaq nx6110 PC Laptop
I have a HP Compaq model NX 6110 laptop,which was working well until last week when it started to freeze but when you press on it especially above the touch pad it works,that trend continued until last night when it went off and up to date its failing to boot. Its quite frustrating especially if work is pending. Please Help!
    Brigadier General:
  • 8,909 Answers
That sounds like you have a bad connection in that vacinity.
Removing the case and resetting the contacts may fix it but it could be a crack on the motherboard.
Good luck.
Posted on Dec 29, 2010
My HP Compaq nx 6110 freezes afta the HP invent screen and doesnt go beyond that, and if i plug the adapter the system boots automatically but not beyond the HP invent screen. Please help.
Hello
Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
press F1 at start up to check the bios for power management settings as perhaps there is a conflict to the settings in Windows. Also I would check what is running in startup (msconfig) and leave nothing but essential antivirus and antispyware. I have seen Norton or MacAfee come up and cause this on several HP Laptops until I uninstalled every last bit of it
also ensure the laptop is in a roomy place a overheating could also be the cause
Dec 15, 2010 | HP Compaq nx6110 Notebook
Audio drivers compaq nx 6110
You can download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
May 17, 2010 | HP Compaq nx6110 Notebook
My Hp compaq laptop can not connect to the
many times this happens what u r saying......
the most probable cause could be non-availability or very week availability of network signals.....
IT COULD be also due to any change you have made to IP adderess
so first get conformed of the IP adderess u are using
Mar 30, 2010 | HP Compaq nx6110 PC Laptop
When I boot the system of my laptop (Campaq nx 6110), the machine freezes at the logo of HP while booting. when it reaches that stage it freezes.
Set your system BIOS to boot from Hard Drive and check if the BIOS detect your Hard Drive too. Remove your Hard Drive and Place it again.
It will fix your problem.
Dec 30, 2009 | Compaq NX6110 TFT XGA Notebook
Wireless is not working
what is your Windows OS? XP or Vista? to activate the wireless, press Fn F2 or just look for the wi-fi switch located above the Function keys or sometimes on the edge of the laptop with a picture of wireless signal or wave or antenna that resembles wireless.
Aug 01, 2008 | HP Compaq nx6110 PC Laptop
Nx 6110 boot up issue
None of the above. Sorry. All those "solutions" are "shooting in the dark". There is a definitive method of determining the problem here, without guesswork.
The "HP screen" you speak of is an "advertising mask" governed by the "quiet boot" option in BIOS.
This HP screen is shown INSTEAD of showing you exactly what BIOS is "doing" at that moment: First, a ROM checksum to verify BIOS is OK, then a quick system check of the most basic components, and if that goes well, the next thing it does is count AND check the RAM. Finally, after all that is done, it will look for a hard drive and query that drive for cylinder or LBA size, then look at MBR for sector zero, to find an operating system.
So here is what you must do to SEE all that taking place:
1. Make sure the system is TOTALLY cold (off, not in any ACPI state). Do this by pressing and holding the power button for 10 seconds, then release.
2. Remove Battery and the PSU (AC power supply)
3. Insert the PSU connector (only) this will also eliminate any battery problems. Batteries with dead cells can pull out so much current that you get slow boot/running performance. More on this later.
4. Now, start the computer, and keep pressing ESC key, quickly. It may start beeping. Stop and wait then.
5. Next, you will see a BLACK screen instead of HP screen. There will be some white text that scrolls. First the BIOS type and version. Next, RAM will be counted, and last, a HD will be reported. Last (or if any of the above have a problem) any errors will be reported. Some BIOS will specify the error, others will report it as "code XXX". Send me (post) this info, and I will analyze the problem.
NOTE: you can hit the PAUSE key at any time, to read the info, if it runs too fast for you. Then press PAUSE key again, to resume the BIOS data post process. Once you have reported back with any errors (as in step 5 above), we can also do this same thing with Windows, to "see" the black screen/errors reported as the PC boots.
Jan 22, 2008 | HP Compaq nx6110 PC Laptop
Compaq nx 6110
Here you have manual for ur pc:
http://rapidshare.com/files/74479443/HP_Compaq_nx6110-nc6110-nx6120-nc6120_Notebook.exe
Let me know if u got help and rate me as fixya please
Dec 05, 2007 | Computers & Internet
My compaq laptop freezes after 30 minutes
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. Have you expierenced that problem also? There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | HP Compaq nx6110 PC Laptop
HP Compaq nx6110 PC Laptop Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
