Question about HP Photosmart A526 photo printer
HP photosmart A526 print cartridge alignment failed - see product documentation. I have just received this printer and the above error is what I am getting on installing the print cartridge that came with the machine. I have looked through the documentation and can find nothing on this problem. Can you help? thanks
leethedeuce
  • 4472 Answers
SOURCE: hp photosmart 3313 all in one
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support. If you need their contact info I can give it to you.
Thanks,
Lee
Posted on Jun 17, 2008
leroyal
  • 2120 Answers
SOURCE: HP 1610 alignment failed error message
replace black also
Posted on Jan 25, 2009
buffalonyman
  • 1865 Answers
SOURCE: HP Photosmart 3310 All in One - just failed
Go to the following link to get support for your printer
http://h10025.www1.hp.com/ewfrf/wc/product?product=439491&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Nov 05, 2009
Testimonial: "Straightforward answer & appropriate link!"
komguy
  • 2306 Answers
SOURCE: alignment failed refer to device documentation hp L7780
You need to remove the black/yellow printhead and dab it on a damp paper towel until you see a solid line of black ink on the towel when you press it. It won't pass the alignment until all colors work properly.
Posted on Nov 19, 2009
Testimonial: "Tried that, unfortunatley not solved my problem argh!!"
  • 5188 Answers
SOURCE: I have a hp psc 950 I set uo align cartridge clear
There are several possibilities that you can check. First, what is the ink level for all colors? You need enough ink in all of the cartridges, black and the three color tanks in the color cartridge. A low ink in any one cartridge could do this.
Second, make sure you are printing on clean white letter or A4 paper (no additional print on the page). Is the paper feeding correctly from the paper tray? Did the alignment page print and arrive in the output tray? Check for a paper mismatch warning or if 4x6 paper selector lever is pushed forward on the output tray. Make sure the selector is pushed all the way towards the printer. Did the alignment page look like the previous alignment pages or the ones shown here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=60259#Alignment_Pages .
If any color is missing, look for a problem with the cartridges. Try running a cleaning cycle: press Menu (or Setup, depending on the printer) on the printer. Press the right arrow until you see Maintenance or Tools. Press OK and then OK again if Clean Print Cartridges is highlighted. (Otherwise, highlight the Clean Print Cartridge by pressing the arrow keys and then press OK.) If the output is missing, faded, or streaked. Note: a low ink issue will be made worse with a cleaning. It is a cartridge issue. This could be a symptom of clogged nozzles on the cartridge, the protective tape still on the cartridge, or poor contact between the cartridge electrical contacts and the matching ones on the print head. Remanufactured and refilled cartridges are at higher risk of failing. However, the chip on the cartridge can also fail; in this case, if you have a genuine HP cartridge, contact HP. Replace the cartridges. You may want to clean the cartridges and the print head. Use distilled or bottled water and lint free paper or swabs. (coffee filters can be used.) Wipe away from the nozzles (the contacts, edges and ramps of the cartridge) of the cartridge and the contacts inside the printer. Wipe in one direction only even on the contacts inside the printer.
Reset the printer by unplugging the power cord for at least 5 seconds before plugging it back in. Print a new alignment page. Does the printer give one or two pages? If you only get one page, the alignment is automatic and you should see a blue light at times as the printer feeds and prints the page. If no light shows up, the printer needs service.
If you get two pages, check the scanner glass and white scan backing. Clean the surfaces with a soft cloth dampened with clean water, if they need cleaning. Check if the bulb assembly is lighting up when the unit is on. If that scanner light doesn't come on, the all-in-one needs service. Make sure to put the alignment page face down on the glass or face up in the ADF. Copy the alignment page. If the copy has vertical streaks, clean the scanner assembly. (If this cleaning doesn't help, again the unit needs service.)
You can bypass the required alignment. Press and hold the Enter button and then press the Setup button. The unit should print but the print quality will be poorer. If any colors are missing, check the ink level and for clogged nozzles.
I hope this helps.
Posted on Oct 28, 2010
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
I have an HP Photosmart A526 printer. I have tried 2 new cartridges and neither print yellow. I thought it was a fault with the cartridges but now think it may be the printer. I have aligned and...
There are two possible malfunctioning in this case.
  • Issue with the cartridge.
  • Issue with the printer.
Its better if we start resolving this issue linearly and logically first by following these steps as given in the manual on the following link.
Please click here:
Missing, Faded, or Dull ColorsIf the above doesn't help, we might try a printer reset to bring it back to the default print settings and configuration.
Performing a Partial Reset
  1. Disconnect any universal serial bus (USB) cables attached to the printer.
  2. Open the print cartridge door and remove the print cartridge.
  3. Close the print cartridge door
  4. Press the Power button to turn the printer off and wait for the printer to shut down before proceeding to the next step.
  5. Unplug the printer AC adapter from the printer and the wall outlet or surge protector.
    NOTE: The adapter itself has an overload trip that may need resetting, but will not reset if power is flowing to it.
  • Wait approximately fifteen to forty-five seconds and proceed to the next step.
  • Plug the AC adapter back into the wall outlet, and then into the printer, but do not plug in the USB cable.
  • Wait for the appropriate missing print cartridge error to verify that the printer can recognize this error.
  • Open the print cartridge door and re-insert the ink cartridge.
  • Print an internal test page.
    1. Remove any memory card, if inserted.
    2. Use the arrows (c01070297.jpg ) to highlight Print test page .
    3. Press Print to begin printing a test page.
    This is how the Test Page looks like:
    If still the printer is not printing the way it should, we might think of going for a HARD RESET by following the steps below:
    Performing a hard reset of the printer
    1. Unplug the power cable from the back of the product.
    2. Unplug the power cable from the electrical outlet.
    3. Wait 15 seconds.
    4. Reconnect the power cable into the product and then reconnect the power cable into the electrical outlet.
    5. If the product does not turn on, press the On button.
    This should bring the printer back to normal.
    Wish you luck.
    Regards,
    techbuddy247
    Nov 15, 2010 | HP Photosmart A526 photo printer
    I just installed my brand new printer cartridge in my hp a526 printer (NEW) and when I follow the instructions for set up to perform printer alignment it failed and will only print re and yellow colors...
    First of all if there is a procedural fault when a new ink cartridge is installed this fautl can occur.
    So first of all remove the printer, Uninstall the software. the reinstall the printer software and on instruction connect the printer to the PC. The new harware will be now installed .
    make a test print. It must work fine.
    Failing this test there can be errors in the printing head / main board.
    Sep 11, 2010 | HP Photosmart A526 photo printer
    Printer will not print
    please understand that this is an issue with the printer hardware and not the cartridges.so dont waste ur money purchasing new in cartridges hence refer to this document
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00723815&cc=us&lc=en&dlc=en&product=1153494
    Feb 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
    My printer says ink system has failed. Refer to
    My HP Photosmart c5183
    printer says ink system has failed. Refer to printer documentation. Error: 0xc18a0406. Please help.
    Sep 24, 2009 | HP Photosmart 3210 Printer
    How do I realign my hp photosmart c4480 printer?
    To align the print cartridges from the HP Photosmart Software
    1. Load letter or A4 unused plain white paper into the input tray.
    NOTE: If you have colored paper loaded in the input tray when you align the print
    cartridges, the alignment will fail. Load unused plain white paper into the input
    tray, and then try the alignment again.
    2. In the HP Solution Center, click Settings.
    3. In the Print Settings area, click Printer Toolbox.
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog
    box. In the Print Properties dialog box, click the Features tab, and then click
    Printer Services.
    box. In the Print Properties dialog box, click the Features tab, and then click the
    Printer Services button.
    The Printer Toolbox appears.
    4. Click the Device Services tab.
    5. Click Align the Print Cartridges.
    When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
    press the button next to OK.
    The product prints a print cartridge alignment sheet.
    7. Load the page print side down on the right front corner of the glass, and then press
    the button next to OK to scan the page.
    When the On button stops flashing, the alignment is complete and the page can be
    removed. Recycle or discard the page.
    Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    New cartridge inserted, received error
    Hi can try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
    Reset the product:
    1. Without turning off the product, disconnect the USB cable from the rear of the product.
    2. Remove the cartridges from the product.
    3. Wait for the 'Insert Cartridges ' message to display on the control panel.
    4. Disconnect the power cord from the back of the product.
    5. Wait 60 seconds.
    6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
    7. Reinsert the cartridges, and then close any open doors on the product.
    8. If you receive a prompt to print a calibration page, do so.
    9. Reconnect the USB cable to the rear of the product, and then try printing again.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Apr 03, 2009 | HP Photosmart 3210 Printer
    Color Cartridge Failure
    You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
    Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
    HP Photosmart A526 photo printer Logo
    202 people viewed this question
    Seeker5211
    Seeker5211
