Question about Maytag EPIC MFW9700S Front Load Washer
What does the error F25 mean - Maytag EPIC MFW9700S Front Load Washer
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for
error code F28
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Whirlpool duet sport error f25
F25 is a communication error between the mcu(motor control
Nov 05, 2016 | Whirlpool Washing Machines
Error code f25 replaced inlet thermador
call a repairman we do not know what you have .
Mar 16, 2016 | Washing Machines
What the F25 code
Please, head over to this link, it explains by a regular user on what F25 means and it have pictures.
http://neighboursappliance.com/f25-on-a-duet-washer/
Sep 22, 2015 | Whirlpool Dryers
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
Front loader maytag stop in middle cycle give error F25
Remove your service panel and look for your tech sheet inside a jacket in the inside of the service panel. An F-25 is usually a broken wire between the main control and the motor control.
Oct 09, 2011 | Washing Machines
I have a Kenmore H2 Plus washing machine. I get an error message that says "F25". What does this mean?
F25 indicates a possible drive motor tachometer error.
Remove
front lower panel-2-3 screws at the very bottom the tech sheet is located in a plastic pouch.
The f25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then reseat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
Jun 07, 2011 | Washing Machines
Its giving the c31.00 error
That error means disc is not inserted correctly and if you are puting the disk in right and getting that
I would say somthing broke in the slot drive.
Feb 27, 2011 | Sony DVP-F25 DVD Player
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE 2 Plus
F25
Sep 27, 2008 | Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
506 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
