Question about Cell Phones
Purchased a binatone bb200 mobile phone for my elderly mother have charged the battery installed her own sim card but when trying to make a call she cannot be heard the phone has a dialling tone and also receives an incoming call but she still cannot be heard any thoughts how to solve please many thanks
5 Suggested Answers
samkong
  • 106 Answers
SOURCE: wont turn on
Please check the charger connector for dirt, if possible take an old toothbrush and clean with alchohol, let it dry and refix everything. should work.
Posted on Jul 25, 2007
bsrjth
  • 270 Answers
SOURCE: sim card rejected
this happens when ur sim cant establish registration with the preffered networkk . this is not a phone problem . ur sim card may not hve been used for long time (recharging account) . please contact the nearest office of ur network provider
Posted on Nov 06, 2008
feelfemi009
  • 277 Answers
SOURCE: Nokia N72 mobile phone, am unable to hear dial
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
Posted on Jul 11, 2009
SOURCE: How do I change SMS alert tone on Samsung Tocco Lite mobile
Go to Menu > Settings > Phone profiles > click the two arrows beside Normal (or whichever one you use) > go to the top of the screen and select New Messages > Choose Message Alert Tone > Sounds > choose the file.
Posted on Mar 19, 2010
Fitted new sim card into new doro phone and tried to charge battery but no joy? keep checking sim is in correctly which i am sure it is! help!
Having the SIM in the phone doesn't affect whether the phone charges or not. I'm guessing either the charger you have is bad or the battery in the phone won't hold the charge.
Mar 02, 2015 | Doro Phoneeasy 410Gsm Easy Gsm Sim Free...
How do I delete the memory numbers in the Binatone BB200 pone please ?
go into the menu on the handset and select factory default.
Jan 24, 2015 | Binatone Lands Phones
Binatone bb200
I've had exactly the same problem. The connector that plugs into the docking cradle (or phone if you don't use the cradle) is faulty. Mine had a short circuit. Try gently moving the cable closest to the connector. Alternatively, turn off the charger at the mains socket, leave for 10 minutes or so then switch back on. If that doesn't prove it and you're lucky enough to have another charger, try that to see if the original is at fault.
Be warned that even though it's a 5.2V charger and a common USB type should work, getting hold of the identical USB connecting cable I found impossible. I had no luck sourcing a replacement Binatone charger either.
In the end I removed the sticker from the base of the cradle revealing the screw then undid it to dismantle the cradle. The cradle is very simple so don't worry. I cut the USB plug off the charger, bared & tinned the wires then soldered them directly to the docking contacts (wire with feint white broken line is +5V and should go to CH- solder pad, the plain black 0V wire goes to CH+). You'll have to cut a small notch in the lower edge of the cradle to pass the wires through before reassembly.
The soldering's very easy but don't overheat the pads otherwise the contacts will fall off which might be tricky to reposition. I'm quite handy with a soldering iron but if you're not, it's only a 5 minute job for anyone that's competent.
Jun 19, 2013 | Cell Phones
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
Misplaced operating manual for Speak Easy GSM Mobile Phone plus&gt; Need to download the Binatone manual for this phone. I am not a young person therefore instructions are vital. Thanks
Binatone don't seem to bother providing a solution to this problem. My mother-in-law has rung to say that the Big-Button BB200 is really faint, can the volume be turned up? I don't know, and I can't find out.
Jan 30, 2011 | Cell Phones
1600 not charging
Either your sim card is not seated correctly, the contacts are dirty, the sim card is dead, the copper contacts in the phone do not reach the sim card or the electronics in the phone are faulty. Try to change a new battery' check the battery terminal contact'.
sometimes is not properly alligned' or maybe your battery is loose in tha back houssing of your phone.
Nov 11, 2008 | Nokia 1600 Cellular Phone
Unlock
i want use it in egypt
Dec 12, 2007 | T-Mobile Wing™ Smartphone
Cell Phones Logo
88 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
