Question about AEG Washing Machines
Lavamat 74620 CE error code. what does this mean and how do i fix it?
3 Suggested Answers
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
read this site: http://www.askanowner.nl/qa/view.asp?s=2&qid=152459&arrqueryparts=&arrquery=code%3Bce kind regards, w vd vegt
Posted on Aug 28, 2007
SOURCE: AEG LAVAMAT 74620 shows "CE" error
I fixed it, but I still don't know for sure what the "CE" error code is. I guess it is for the water distributor. I opened it up. There are some gears in there that move a mechanical arm that distributes the water into different containers. The mechanical arm moves around an axis -- it was very difficult to move, so the gears kept slipping. I opened it, and put some greaze inside. Closing it up was a real pain. But it works, and I didn't have to wait around to receive a new distributor.
Posted on Dec 28, 2008
Lavamat 74620 pumps out and does nothing no error codes? Door locks drain pump does nothing and no water fils motor does not spin. Is it the main control board? Brushes look ok on motor fan belt ok
Have you checked for anthing that has gone into the drain filter, there should be access to the filter via a small access way at the front of the machine either left or rihgt side at the bottom. Your instructon manual would give directions on how to access the filter location to check the filter is clean and should be checked regularly to keep your machine running correctly.
Dec 13, 2016 | Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
AEG Lavamat 74620 shows a Cd error code. Can you tell me what problem this indicates.
CD means door lock is defective. this may be due to the door catch broken or even the main board being defective.
Nov 23, 2010 | AEG Washing Machines
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
My AEG lavamat 74620 doesnt fill up with water
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
May 06, 2009 | AEG Lavamat 72640 Front Load Washer
AEG OKO_LAVAMAT 74620 gave me a code error C7. What is it?
take off the bottom front panel, a booklet is taped to the right side of the panel for the sevice tech it has all the codes
Feb 28, 2009 | AEG Lavamat 72640 Front Load Washer
Dec 27, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
