Question about Maytag Performa PAV2200
Gasket on refrigerator door
The do will not shut completely
  • 639 Answers
Just call service.
But if its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Posted on Aug 24, 2008
Doors not sealed correctly on Maytag refrigerator
Door gaskets have a magnet that holds the door shut. Place a dollar bill between the gasket and cabinet and pull that dollar all the way around the door. You should feel some resistance, and if the bill is loose in any ares, heat that area of the gasket with a hair dryer. Once you have completed this on both doors, your problem should be resolved.
Jul 21, 2014 | Refrigerators
Water leaking onto floor lower left side
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls
Hope this helpout....
Aug 15, 2010 | GE Refrigerators
Water dripping inside refigerator
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Hope this helpout.......
Aug 15, 2010 | Kenmore 53642 / 53644 Side by Side...
Water leaking from freezer
1. Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
2. Step 2 Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets
3. Step 3 If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Check out this link, its a video shows you how to fix a leaking fridge.
Apr 21, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The door doesn't shut easily. Plastic spacer is broken? Can I find a new part?
Apr 17, 2010 | Refrigerators
Water dripping down the freezer & builds up on the bottom
Apr 17, 2010 | Kenmore Refrigerators
Water at the bottom of frig inside under crisper draws.checked door gasket it is fine cant see where water is comming from . any ideas
Apr 12, 2010 | Whirlpool ET1FTKXK Top Freezer...
Water is coming out of the freezer part, just from under the section the eyes and water are dispensed, the temperature light keeps flashing on and of at -22 degrees and everything inside is melting. What...
Apr 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Refrigerator appears to be working correctly, but alarm beeps three times every 2-3 minutes
Make sure the doors are completely closed, and the gaskets are not leaking. Shut the doors and put a srewdriver between the gasket and the fridge and pull the gasket back a little to make sure the light inside is off.
Sep 08, 2009 | Frigidaire Refrigerators
Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
Washing Machines Logo
37 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
