Question about Parmak Solar Fence Charger
Why do my horses keep going through the fence in the winter? We have the 12v solar unit! It seems as though there is a delay with the shock!
Trim your horses whiskers (on the muzzle) and they won't be able to tell if the wire is hot or not. Horses test electric fencing with whiskers. I would suspect because days are shorter and more cloud cover your charger is not producing enough power.
Posted on Jan 04, 2011
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
I have a paramark solar charged fence model number df-sp-li it dosen't click anymore how come? Is the click important
The click is the transformer carrying current. If the unit doesn't click, unhook the fence from it and turn it on. If it starts clicking it is a short on the fence. If it doesn't then the unit is not working. contact parmak and they can service it or sell you a replacement circuit board which is the most common failure.
Sep 24, 2012 | Parmak Solar Fence Charger
No charge, is it battery or solar panel, how do I tell
if the unit is not produceing a charge during daylight then it is the unit. the DF-SP-LI will produce full power under sunlight alone. test the unit with the fence unhooked.
Jun 01, 2012 | Parmak Solar Fence Charger
12v solar charger is not clicking when turned on.
disconnect the unit from the fence and turn it on. if the fencer work(ticks, meter moves) then it is a fence issue(short, broken wire). if it doesn't then it is an issue with the unit its self and it will probley need a PCB or service.
Oct 22, 2011 | Parmak Solar Fence Charger
When my Mark 6 does its job and shocks a cow it pops the GFI that it is plugged in to. How do I fix that?
Replace the GFI with a standard plug. the unit has its own ground return which cause the GFI to trip.
Jul 10, 2011 | Parmak Solar Fence Charger
Solar pac 12 Battery has charge...panel is delivering charge ...No needle action when turned on and no current at bottom lugs...Thank you for your help.
With the fence connected or not?. with; then disconnect and turn it on again . if it works fence problem if not unit problem. with-out; unit problem . most likely PCB
Jun 26, 2011 | Parmak Solar Fence Charger
Ok, i feel pretty dumb. apparently the horses ( or maybe the wind? ) knocked the top off the solar panel box. i went to hook it back up.... which wires go where???
Red to red , black to black . or if it is an older version white to white black to black . a mixed version would be w/b b/r
Nov 12, 2010 | Parmak Solar Fence Charger
I bought a Parmak Solar Pak 6. I wanted to use it
when you touch the wire, you are probably wearing shoes, which ground you,
touching it barefoot or kneeling on bare knees should provide a bit more jolt.
take your multi-meter, shove one probe in the ground and touch the wire with the other and you should get a nice reading
May 08, 2010 | Parmak Solar Fence Charger
No shock from charger
did you make sure the fence isn't grounded or an insulator hasn't melted
Apr 12, 2009 | Parmak Solar Fence Charger
Parmak Solar Fence Charger  Logo
249 people viewed this question
Top Parmak Electrical Supplies Experts
 Kenneth
Kenneth
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
