Question about Frigidaire FAC124 wall/Window Air Conditioner
FAC124P1A1 window unit
When the unit is running water droplets are hitting the fan blades and spraying water within the rear housing. Is this normal because it makes alot of noise.
Frigidaire told me in an e-mail that there is a single motor, "with two shafts and water droplets hit the fan blades and are then sprayed on the condenser coils to cool them". This is by design, I guess.
Posted on Jul 18, 2008
    Novelist:
    Champion:
  • 230 Answers
It is probably freezing up and then thawing. Try cleaning the filters and running it at a higher temperature for a while. If it goes away then you are finished. If it does not go away you may need to bring it to a service center to have the refrigerant levels checked.
Posted on Jul 07, 2008
Exhaust fan is hitting something while running
The fan blade shifted (moved) on the motor shaft. Take it apart (usually from the rear) and move the fan blade a 1/4 to 1/2 of an inch to clear the housing. Don't add oil to the shaft otherwise it will move again.
Jun 25, 2013 | GE Ovens
My unit is throwing water out of the front vents not a lot. It sound like the fan blade is hitting water It still cools but makes a loud noise .R bordeaux
The water and noise you hear is from the fan blades hitting backed up water in the drip pan. This occurs when the drain hole near the rear of the drain pan is clogged and/or the rear of the unit does not have enough downward tilt. Which allows the water to flow freely to the drain hole. The general rule of thumb for downward tilt is 1/4" to 1/2". Correcting these to things should solve the problem. Be sure to turn the unit OFF & Unplug it, before attempting remedial service work on the unit.
Hope this helps you and thanks for choosing FixYa.
Aug 22, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Why does wall make ticking noise
Marvin, it could be water dripping into the drain pan under the unit or the metal of the outer shell is cooling off (metal stress). Also, is the drain pan is full the fan blades may be hitting the water, In which case the rear of the unit needs to be tilted down 1/4" to 1/2". So, the water will flow to the rear of the pan and out the drain hole.These sounds are normal and will do no harm. If you want to test this theory, turn the unit OFF & unplug it. If you still hear the ticking sound, it's one of the above.
Hope this helps & thanks for choosing FixYa.
Aug 11, 2011 | Frigidaire FAC124 wall/Window Air...
Lately at certain times while running for days it makes a clanking noise(sounds like the fan) I spray water through the back of it with a water bottle and after 20 min the sound slowly go's away.It is...
This is normal, the noise you here is most likely ice build up on the condenser coils. when the outside temperature is under around 15c ice will build up on the condenser coils it then falls and hits the fan blades. this will also happen if the unit has been running for a while. there is no need to spay water into the unit as this can cause damage to the electrical components.
Jul 12, 2011 | Emerson Quiet Kool 12JW42K Air Conditioner
Our unit is making loud clicking noise and spraying water when in the cooling air condition mode, but not when the fan is on. What could be the problem, and is it fixable?
you may hear water splashing that is because it is coming off of the condenser the part that is outside the water runs off the condenser and is forced out by the fan for as the noise could be something in or on the inside fan blade or outside fan blade as long as the water is not coming inside your house and you have enough slope on the unit you should be ok
Jul 04, 2011 | LG Electronic Window Air Conditioner
The thing that resembles a plastic fan blade is
This normally means it is hitting the housing around the blade probably because it has become warped (due to heat) or has a crack in it. It generally start to break away from the motor spindle within in weeks of the sound you're hearing. You need to replace it at some point.
Dec 24, 2009 | Dryers
Window unit just started spitting a little water and making a noise like when something is too tight a fit, a rubbing noise. just started minutes ago. it's raining but, what could of happened?
Make sure the window unit is evenly placed inside the window frame.Just a slight twisting of the housing will cause the fan blade to scrape the housing. Make sure that the fan blade has no come loose from the fan motor shaft if that does not solve the problem. Also make sure the window unit tilts slightly downward so that any water from the condensate produced inside the home on the condenser coil can drain down the slope to the outsidelike the way explained. I have also seen units that were positioned correctly but the drain trough is blocked and will not allow the water to drain outside the house. Let Me Know, Thanks, Sea Breeze
May 15, 2009 | Haier hwr10xc6 Air Conditioner
CW-XC243HU A/C Water Spray
Hi, It probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit through passage ways to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt or algae in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem. Since the tilt is right and it doesn't seem to be freezing, Maybe a temporary increase in tilt and a dropper of bleach at the base of the evaporator would do it. This will kill the algae and may unblock the water flow. NOTE: It may also cause stains on a carpet or floor if the bleach water drips onto it. If you want to pull it out and clean it, most units can be pulled out of the housing and sprayed with a water hose but you need to be careful not to get water in the electrical parts of the unit. They can be covered with plastic or foil. Make sure you unplug the unit before trying to remove it. You may have to remove some screws to remove it from the housing. Hope this has helped. kstfas
Sep 19, 2007 | Panasonic CW-XC243HU Air Conditioner
Water in housing
You will need to clean the evap coil with a bleach type product and then hose out the condenser coil as well. The bleack will also remove algie from the evap water pan. THX RepairUSA
Aug 26, 2007 | Goldstar R5050 Air Conditioner
Water is not dripping from window A/C unit, air is cold but damp
HELLO .. HOPEFULLY YOUR UNIT SLIDES OUT OF THE A/C HOUSING, IF IT DOES REMOVE IT. (THERE MAY BE A FEW SCREWS HOLDING IT IN PLACE USUALLY BEHIND THE FRONT GRILL) PUT DOWN SOME OLD RUGS FIRST AND HAVE SOMEONE HELP YOU SLIDE IT OUT. GET OT THE GARDEN HOSE AND SPRAY NOZZLE. PROP UP THE FRONT OF THE UNIT SO IT DRAINS TO THE REAR. BOTH THE EVAPORATOR COIL AND CONDENSER COILS SHOULD BE CLEAN. YOU WILL NOT SEE DIRT ON THE OUT-SIDE OF THE COIL ... IT WILL BE ON THE INSIDE HIDDEN BY THE CONDENSER FAN BLADE. BE VERY CAREFUL NOT TO BEND THE FAN BLADE WHILE INSPECTING OR WASHING. BE EXTREAMLY CAREFUL TO COVER THE MOTOR AND ELECTRICAL CONTROL BOX WITH PLASTIC BAGS TO ENSURE ALL ELECTRICAL COMPONENTS STAY DRY. FACTOID: 90% OF AIR CONDITIONERS THAT "DONT COOL AS WELL ANYMORE" IS DUE TO DIRTY COILS. THERE IS ALSO A TUBE OR CHANEL THAT DRAINS THE WATER FROM THE EVAP (FRONT) COIL TO THE BACK OF THE UNIT. THAT CONDENSATE WATER IS SUPPOSED TO ACCUMILATE IN A SNALL RESEVOIUR WHERE THE SLINGER RING ON THE OUT SIDE COIL FAN BLADE PICKS IT UP AND HELPS COOL THE HOT CONDENSER COIL. SOME OLDER UNITS MAY NOT HAVE A SLINGER RING AROUND THE OUTSIDE OF THE BLADE. NOW ... MAKE SURE YOUR OUTSIDE FAN BLADE IS CLEAN. AS WELL AS THE INSIDE BLOWER FINS ON THE "SQUIREL CAGE". NOW THAT YOUR UNIT IS CLEAN AND YOU CAN SEE CLEARLY THROUGH BOYH COILS, GO AHEAD AND OIL YOUR MOTOR. CHECK TO SEE IF YOUR FAN MOTOR HAS "OIL CAPS" USUALLY THEY ARE AT THE TOP OF THE 2 ENDS OF THE MOTOR. IF THERE ARE CAPS REMOVE THEM AND USE A STRAIGHT WEIGHT (NON-DETERGENT OIL). SOME WINDOW A/C'S UNDER 12,000 BTU'S ARE SEALED UNITS. IN THAT CASE YOU WILL HAVE TO REMOVE THE UNIT FROM THE WINDOW MOUNTING BRACKET. AND FOLLOW THE SAME PROCEEDURE AS LISTED ABOVE. GOOD LUCK AND STAY DRY.
Jun 17, 2007 | Fedders Y Chassis A6Y18F7A Air Conditioner
Frigidaire FAC124 wall/Window Air Conditioner Logo
203 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
