Question about Interactive Toy Concepts Crossfire Arctic Cat Rc Snowmobile
96 wildcat 700 only has half power like it only runs one cylinder have spark on both
    President:
  • 1,978 Answers
You probably have a bad clutch seal on your crankshaft, or one dirty carburetor, or possibly bad spark plug caps. Clean your carburetors, change your plug caps, and test drive the machine carefully. If it still bogs , buy an after market piston kit with crankshaft seals, gaskets, pistons, and rings. Do a complete rebuild it should only cost about $150 for all the parts in a kit. Then you should be good to go for another 17 years.
Posted on Jan 23, 2011
  • David Belcher
    David Belcher Feb 04, 2011
    Last weekend I had a similar experience to the condition you describe. The repair (on the trail) involved pulling off the carburetor top and reattaching the throttle cable to the piston. It had slipped off piston and just needed to be put back on.
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
My 98 xr400 will not start. It seams to be flooded but it doesn,t even sputter if I don't move the choke at all. If I put the choke on half open it almost starts but then I think it floods. I changed...
Check to see if you have spark. Put a plug in the cap and touch the cylinder , kick it over to see if the plug is sparking. I kick mine 2 or 3 times to prime the cylinder holding decompression lever in. If it pops on full choke but does not start I go to half choke. If it does not start after 3 or 4 kicks , then I turn off the choke and kick it over 5 or 6 times with the decompression lever pulled to clear it. Then I will kick with no choke or half choke. Honda's are notorious for being cold blooded so when it starts let it warm up and do not be afraid to drive a short distance on half choke till the motor warms up a little.
When the machine is hard to start after sitting I usually start by removing the carburetor and shooting carburetor cleaner through the jets and passageways.I have always found my 96 xr400 to be a dependable starter with fresh gas and a clean carburetor. If it is flooded use the decompression lever to clear the cylinder.
Dec 31, 2010 | 1998 Honda XR 400R
83 honda silverwing was running fine. stopped and got gas and started funny like half power for half the ride home, then takes off. replaced both spark plugs and was running fine for about 2 miles. noticed...
sounds like a spark problem ,coils once the carbs load up it takes off and the extra fuel in the cylinder is not fireing so you get a back fire check the plug gaps and make sure it;s the right plug , then check to see what kind of spark you have if it's weak replace the coils
Aug 07, 2010 | Honda Silverwing 600 Motorcycles
Have a 94 wildcat 700 and is running of 1 cylinder need help
check the spark on the dead cyylinder, if there isnt any, replace the coil, this is the little box that the sp wire goes to
Feb 11, 2010 | Interactive Toy Concepts Crossfire Arctic...
96 ford taurus ran fine yesterday go on 25 mile trip half way through trip engine runs ruff. Like miss firing just changed plugs about two weeks ago it idles ruff but runs doesnt stall at all. baffeled
sounds like spark plugs or spark plug cables are bad and it is in fact misfiring this happened to me in my car and my spark plug cables were bad
Aug 29, 2009 | 1996 Ford Taurus
96 dodge caravan 3.0 has p300 and p306 codes,
A P0306 code means that the the ECM has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #6.
A code P0306 may mean that one or more of the following has happened:
Faulty spark plug or wire, Faulty coil (pack), Faulty fuel injector, Burned exhaust Valve, Poor compression, and Defective computer.
Check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the Caravan, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). The number six cylinder is the one towards the radiator and drivers side. If you are going to change all the plugs and wire keep me posted, be glad to help. Good luck and hope this helps, P0300 just means multi miss fire.
Jun 22, 2009 | 1997 GMC Jimmy
Not getting oil in top half of enginge 97 pontiac transport
Fuel in Cylinder Is CAUSED Most Likley BY THE MISSFIRE Check Spark at that Cyl. & Correct that. ALSO Fuel in oil Breaks Down Viscosity of the OIL so I Would Eliminate the Fuel in OIL Problem First to Determine if No Oil Pressure in top end
Feb 11, 2009 | 1997 Pontiac Trans Sport
Interactive Toy Concepts Crossfire Arctic Cat Rc Snowmobile Logo
225 people viewed this question
Top Interactive Toy Concepts Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
