Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Error code eo4 and washer does not spin or drain properly
  • Bosch Master
  • 2,605 Answers
Welcome to fixya.
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely.
You haven`t mentioned if you`ve actually visually checked the pump...it is likely just that, a blocked pump.
Anyway, here`s the most likely way to remedy a E04 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain )
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
3. Find a drill bit or small screwdriver that fits in the hole in the round door.
4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan. This will deal with the door lock issue but it likely isn`t unlocking due to the water in the tub )
**There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.**
6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, or a lock, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
Regards,
Macmarkus :)
Posted on Dec 29, 2010
The washer stops at "3". It washes fine and stops at "3". and doesn't drain beyond that point. What is causing this stoppage? Help! My husband is handy.
Posted on Jun 20, 2011
Washer fills with water when not in use. Doesn't completely drain and spin cloths, and I get an E10 error code
Hello Lahoma, thank you for your post!
I understand that your Frigidaire washer fills with water, will not drain completely, and is flashing an "E10" error code. The error code stands for your washer fill time is too long. This could be an issue with your water valve, main control, or water pressure. You should check to make sure that your water flow is normal and that your water line is not restricted. This could cause an issue with the way water is distributed within your washer. The water pressure coming into your washer should be at 30 PSI. You can also clear out any false error codes by performing a reset on your washer. In order to reset your washer you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue I would recommend consulting with a professional technician for a proper diagnosis to be completed. I hope this information is helpful to some degree. -Matt
Mar 18, 2015 | Frigidaire Washing Machines
Control Module problem?
It sounds like the pump or drain hose is blocked by something, and if the water does not drain away it will not spin properly.
The last resort would be the control module which is about one hundred and fifteen pounds, so check everything else first.
Jun 13, 2014 | Hotpoint WMA66 Front Load Washer
Bosch washer code eo4
Being a drain issue , you need to remove the drain pump, check the filter and also check on the outlet , click catchpot
Jan 20, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
WHAT IS E0 ?
Hello there and welcome to fixya
The error code "OE" indicates a drain error. This error will display if the washer is draining too slow or if it's not fully drained in within 10 minutes. This would also explain why it's not spinning properly.
The drain pump filter will need to checked and cleaned
May 28, 2012 | Washing Machines
How do I clear error code eo4 on my casio ce 3700
What were you doing or trying to do when you got this error code?
Apr 09, 2012 | Computers & Internet
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Keep getting error code sd or 5d and sometimes a F error on my HE 2plus washer. Is there an inexpensive solution to the problem or should we be shopping for a new washer?
Hi
The Sd or 5d indicates that excessive suds are detected by the washer during the drain or spin phases of the cycle. The washer will stop and fill with 4 liters of water and then wait for 5 minutes to allow the suds to dissipate before continuing. If the suds cannot be reduced or eliminated so that the washer cycle can continue, it may stop and display the F21 (long drain) fault code. After the suds dissipate, you can normally drain the washer and spin out the clothes using a RINSE/DRAIN & SPIN cycle. Make sure that you are using HE (High Efficiency) detergent in the appropriate amounts to prevent excessive suds in the washer. This should prevent the washer from going into this routine.
And if you still face the same error then probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Also refer to these diagrams for more details--
Kenmore Drain filter and pump link1
Kenmore Drain filter and pump link2
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Jul 13, 2009 | Kenmore HE2 Plus Front Load Washer
F02 & SUDS error + no spin
The "F02" error code is a slow drain error. If you have confirmed your dry lines are clear, you may have a drain pump that is either clogged, or is not working properly. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
It doesn't take much to damage the drain pump on these washers. If something is lodged in the pump for extended periods it could potentially damage the pump impeller or pump motor. The pump may SOUND like it is working, but it may not be pumping. If a good cleaning doesn't work, you may have to replace the drain pump. Replacements are available at searspartsdirect.com.
The "SUDS" error may be caused by a drain pump this is not working properly as well. If the pump gets air inside, it will begin to cavitate and can cause the "SUD" error to appear. Just to be sure, you can refer to this link as well:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
If your washer is not draining properly, it will not spin, either. I think your spin problem may be directly associated to a drainage issue. Begin with a an inspection and cleaning (if required) of the drain pump. I suspect this may be the cause of all your symptoms.
I hope you find this information helpful. Please post back with any questions or comments you may have.
Sep 03, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
512 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
