Question about Dryers
I took out my GE Dryer drum so I could replace the heating element. Had no problems pulling the drum out and releasing the belt. Got the new heating element in and now I can't get the drum to slide back in and seat properly. That shaft goes in and it seems to be aligned properly but the front of the drum is resting on the motor and it doesn't rotate freely. I have the belt hooked back up properly and everything seems to be reassembled. I tried for 2 hours twisting and turning, pulling the drum back off and on. Should there be some sort of locking sound or snap when it seated properly? Very frustrated... Thanks for your help! John
  • Dryers Master
  • 7,482 Answers
Hey John...
Go to this website and it has some pictures of the routing of the belt, maybe you have it routed wrong. I hope this helps... www.applianceaid.com/images/belt-config.JPG
Please rate me
Posted on Dec 29, 2010
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
How do I replace the heating element in Maytag Dryer SDE2606AYW Serial# 12508837EN
1.Unplug the Maytag dryer from the dryer electrical outlet and pull the dryer away from the back wall.Use a putty knife to press in the locking clip between the front and top panels.While pressing the clip in with the putty knife,lift the top panel up to unlock it from the clip.Raise the top panel into the service position allowing it to rest on the back hinges.
2.Locate the door switch connection on the inside front right corner of the Maytag dryer.Press the locking tabs in with your fingers and pull the wiring harness away from the door
switch.With a Phillips-head screwdriver,remove the screw on both inside corners that secure the front panel to the sides. Lift the front panel up and away from the dryer.
3.Use a Phillips-head screwdriver to remove the four retaining screws that secure the drum bulkhead to the front of the side panels. Remove the bulkhead from the dryer.Reach under the drum and pull the idler pulley to the left to release the belt tension.Remove the belt from the motor and idler pulley. Lift the drum up and out of the dryer unit bringing the belt with it.
4.Remove the two screws that secure the heating element to the rear bulkhead with a Phillips-head screwdriver.Disconnect the heating element terminal wires by grabbing them with needle-nose pliers at the wire leads and pulling them off of the terminals.
5.Place the new Maytag dryer heating element into the dryer and slip the wire leads over the terminals.Secure the heating element to the rear bulkhead with the retaining screws.Lift the drum and belt and place the drum back inside the dryer cabinet.Route the belt around the motor and idler pulley.Shift the idler pulley back to the right to apply belt tension.
6.Reattach the front bulkhead to the dryer using the four retaining screws.Position the front panel into place and secure it to the sides with the retaining screws.
7.Bring the top panel back down and push the front corners in to engage the locking clips.Push the Maytag dryer back into its working position and plug the power cord back into the dryer electrical outlet.
Aug 28, 2010 | Maytag SDE2606 Electric Dryer
My GE dryer was making some squeaking sound and now the heat does not work and clothes are not getting dry
Check the dryer dual-breakers in the house electrical panel--push off, then on. If no help, check for ~230 volts AC at the two slanted slots in the dryer power socket. If ok, the problem is likely the heating element(s) in back of the drum are burned out or the internal thermostat is open. To remove the drum, remove the top (push a thin putty knife rearward at each front corner to release latches) and then the front panel. The belt must be released (from inside the lower back) and the rear center screws of the drum removed. When the drum is removed, it gives access to the elements and temp control switches. Be sure to vacuum out all air passages and wash the lint filter in hot water and detergent to remove fabric softener deposits. Don't forget the air exit hose to the outside. Replace the belt on reassembly if heat damaged or badly worn. Hope this helps!
Nov 15, 2009 | Blenders
Dryer no heating how do I get to the fuses and the heating elemet
using a wide flat screw driver pry the top up at the edges betwenn the main top and the front panel. Lay it down on it's back for this. Now look for your door switch wires and undo them. Now look inside the front panel toward the top and remove 2 attaching screws or hex screws. Lift panel at top and remove. Now undo 3 screws in middle of inside drum and pull drum out after un-doing belt. There you should find your heat element and all the thermostats and the thermal fuse should be labeled. If heat element is not broken then chances are your thermal fuse is bad replace it
Feb 28, 2009 | GE DVLR223 Dryers
GE DVLR223 Not Heating--Is there a reset?
There is no reset. What he did was probably replace the thermal fuse. Why did he not clean it out for ya? Anyway when the thermal fuse goes bad either the whole dryer or the heat won't work. If you can open the dryer up by removing the front panel, you can test your thermal fuse for continuity. If none replace it. While you have the front off undo your belt and remove the 3 screws that secure the rear of the drum (inside drum in middle at back) pull drum out and make sure heat element is not broken. Here is a site for your dryer check it out. www.repairclinic.com/Appliance-Parts?s=t-dvlr223-%3d%3d&z=100 Good Luck
Jan 11, 2009 | GE DVLR223 Dryers
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
Where do I find the heating element in my hotpoint dryer
Heating element is behind the drum. Disconnect power. Use putty knife to release 2 spring clips holding top at front edge of dryer. Swing top back. Remove two screws holding dryer front to sides near open top. Swing dryer front to the side. (you don't have to disconnect the door switch wires) Remove plastic tub block at top center of opening. Release belt. Pull up on back of drum, then pull drum out through the open front of dryer.
Sep 12, 2008 | Hotpoint NLL113EYWO Electric Dryer
Help!!!
Further dissassembly is required. You'll want to do this anyway to inspect the heating elements. Some of what I say my not apply to your model (because you did not list a model number). 1. Disconnect power to dryer. 2. open door and remove screws going up into the dryer top. (two or four) Usually these are phillips screws, but you may find tri-wing phillips or T-15 torx. 3. swing top back, allowing access to remove the two screws holding the front panel to the side panels. (near the top) 5/16 hex or twin drive (phillips / #2 robertson square drive) 4. tilt front panel forward, lift off and swing to the side. You don't have to remove the door switch wires if you don't want to. 5. Pull drum forward a few inches. (it's a tight fit to get it past the dryer sides) 6. release dryer drive belt. 7. Finish removing the drum.
8. inspect coil heating elements. If one or both have a break in them, you can replace just the coils, you don't have to get the entire big metal part that holds them. 8. Clean and reassemble. (check the teflon rear drum sleeve bearing and the front drum support slides. now's the easiest time to replace them if needed.) 9. put the drum back in, then the belt back on by reaching your thin arms way back to the belt tensioning pulley. The grooved side of the belt touches the drum and goes down directly to the motor drive pulley on the left, then around the tensioning pulley. 10. Put front back on dryer. 11. turn drum by hand several revolutions to make sure the belt is not twisted or comes off. 11. Finish reassemble, connect power and test. You're done !
Aug 31, 2008 | GE Dryers
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Dryers Logo
Top Dryers Experts
