Question about Maytag Dryers
Why is my Maytag LED 412 dryer making a high pitch, like metal on metal, noise when drying?
  • Maytag Master
  • 7,482 Answers
Your dryer is making squeeling noises because the drum rollers are in need of lubrication or replacement.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Remove the lint filter, and the two screws that hold the filter holder to the top of the dryer.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Dec 29, 2010
The electric dryer will heat up to dry the clothes but it has a high pitch noise when you start it and periodically during the drying time it will make that sound. At first I thought it was the belt but...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 25, 2011 | Maytag Dryers
My dryer is making a high pitch squeaking noise during certain times of the drying cycle. Is it one of the wheels that turn the drum? Don
heatman101
Sep 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
Dryer makes a high pitch squeaking noise
This could be a dry support bearing, a dried out drum seal or something stuck in the drum seal. If I could hear it I would know better where to start. Listen and try to locate the source from the above list. It could be the belt but that is not as common.
Eric
May 20, 2010 | Dryers
I Have a maytag Electric Dryer the dryer is
it could be your drum glides in the front of the drum or the rear center bearing or rear rollers, or the belt idler pulley or motor end bearings going bad,you will need to remove the front cover by removing lower kick panel screws near the floor and lifting upward on front cover,then remove top cover screws located under top cover and lift up and secure so as not to break wires to control panel,then rotate drum by hand and listen for noise location
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
Dryer makes a whining noise when drying
The belt is not the problem but more likely the drum rollers or drum bearing will need to be replaced.
Jan 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes a high-pitched, continuous noise during drying cycle. It's a Maytag, model # LDG9304AAE. Thanks!
It looks like a lubrication problem. Either in the motor or the bushing at the back of the dryer.
Nov 07, 2008 | Dryers
Maytag Atlantis dryer
Why is Maytag Atlantis is not drying like it use to?
Nov 12, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
100 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
