Question about Canon PC-795 Copier
Paper will not feed through machine
Paper will not feed from paper tray. Sounds like rollers clanking and trying to work. Get error message of paper jam in middle of machine. Checked for paper clips, none found. I did find big brass like screw laying in copier when I opened it. ???
    Sergeant:
  • 329 Answers
Brass screw is probably the chrome packing screw which normally sets in a hole near the front of the copier when you open the "**** shell" Paper pick up could need feed wheel. clean with fantastic or soap and water and see if it helps. Also on this model check your exposure lamp is it coming on, if not it may on flicker, On all these PC when the lamp goes bad the paper jams usually at turnaround. Good luck.
Posted on Jul 09, 2008
My printer shows up E2 paper out but there is penty of paper in the tray.
Looks like the main roller is broken, there are mainly two rollers in the printer to feed the paper in, if one of them brakes can cause this problem, Changing the roller will fix the problem.
Hope this helps, please rate and leave a comment, thanks!
Oct 27, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I was copying using the rear paper tray when I got an error message. "Paper output slot. The paper is jammed. Clear the paper and press OK." I do not see any paper. When I turn it on, it...
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Check this link for tips;
http://www.ehow.com/how_113761_clear-printer-paper.html
Aug 09, 2011 | Canon Office Equipment & Supplies
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
I get the same message coming up "remove paper standard tray"
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Jul 20, 2009 | Ricoh Aficio AP3800C Laser Printer
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Media Jam Fuser
I got that error turning off the machine in the middle of printing, opened the door to back, unlashed the 2 green tabs to the final heat roller towards the top and there was my page. i gently pulled it out error gone.
but in your case sounds like the paper is having a hard time feeding through all your rollers or the first one... in that case it has to torn down to the first roller and inspected for paper pieces , what ever, and I clean the rollers with laquer thinner rubbing hard on the black rubber until that high gloss is gone.
Jan 02, 2008 | Konica Minolta magicolor 2300DL Laser...
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Paper jam
If Hp laserjet change rollers? If any kind of printer roller get rubber rejuvination liquid at an electronic store.
Oct 23, 2007 | Brother MFC 8500 All-In-One Laser Printer
No paper detected
Try cleaning the rollers if that doesn't work, remove all of the rollers (feed seperator and retard) then simply reinstall them. This fixed the errors we had.
Feb 14, 2007 | Canon DR-7580
Canon PC-795 Copier Logo
127 people viewed this question
old marine
old marine
