Question about Dryers
Our Whirlpool Model LEQ9858PWO just stopped working. It sounds like the function timer might be running and the start button has it's first click when pushed. With the dryer door open and holding the door switch held up to represent the door being closed and pushing the start button I still just get a click from it. Can you please help me with this problem. Thanks Dave
    President:
  • 1,554 Answers
The problem is usually caused by a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Posted on Dec 29, 2010
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Instructions for oxo model 1061978
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Feb 17, 2013 | Oxo Hardware & Accessories
Whirlpool oven range panel says loc?
This is the control panel lock. Press and hold Start for ~5 seconds until the tone sounds to toggle the lock off. This will only work to toggle off the lock if the Timer and the Timed Cook function are not in use.
When the Lock is active, you can use the Clock, Timer Set and Timer off buttons. Manuals are available for Whirlpool GY396 ranges here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?form_state=literatureSearch&context=&siteCd=WHRCOM&form_state=literatureSearch&searchTerm=GY396 . If this link doesn't work, start here: http://www.whirlpool.com/custserv/index.jsp and enter your model in the Manuals and Literature search area.
I hope this helps.
Mar 12, 2011 | Whirlpool GY396 Electric Kitchen Range
My Whirlpool Inglis Model IED4400SQ0 dryer just stopped. The fuse is fine. I think the problem might be in the start button but I'm not sure. I think this is it because the dryer stopped 2 days ago, then...
this doesn't have a board in it so you either have a bad timer or motor,i would think it would be the timer,try tapping on the timer with a screw driver or something light or wiggle the timer knob and see if it starts,also did you have this on timed dry?it sounds like the timer died and then somehow power went through it again and it ran,the timer controls how long the dryer will run so this is why i think it could be the timer,or a broken wire but try wiggling the knob and see if it starts.let me know thanks.
Dec 22, 2017 | Whirlpool Inglis IP8200 Dryer
Whirlpool dryer model #LER8620PWD serial #MS3630316. I need to hold down the start button and rotate the timed cycle knob for dryer to turn on .
Sounds like you have bad contacts in your timer. By holding the start button and rotating the timer you are just finding a good contact point and allowing timer to send power to the motor. The timer part number is 3979618 and will run you about 90 bucks. hope this helps
_MJ_
Dec 14, 2010 | Whirlpool Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
My whirlpool dryer stopped working today and will not put out any heat, do you know what might be the cause? Model # leq9858pwo
Short answer if the dryer drum still runs, but there is no heat: 90% it's one or both of the heating coils. 10% it's the control switch or relay.
If the dryer will still start and the drum will still turn, find instructions for how to test the heating coils. The test for the coils must be done with the dryer UNPLUGGED! It will involve taking a panel off the dryer.
Nov 24, 2009 | Whirlpool Dryers
Whirlpool GSQ9669LW1 SN: CP3914860 When you try to start a load and set the timer it will just make a clicking sound on and off real fast. The machine turns on for a split second and the motor starts but...
sound like a pressure switch for the fill solinoid.. are you on a well.. or are there other water consuming devices running while you are trying to do laundry.. such a a dishwasher, sprinklers, showers ect.. if there is not enough water pressure some of the newer units they will not even turn on due to the lack of water pressure..
Nov 11, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Model LEQ9858PWO Whirlpool Electric Dryer-- Wife heard a clunk.
Your wish came true, DS! Click here and browse through the sub-components section.
Your lucky day,
SG
Apr 06, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
225 people viewed this question
Top Dryers Experts
