Question about Nikon D80 Digital Camera with 18-135mm Lens
Pop up flash nikon D80
The pop up flash will not pop down! Any ideas?
  • cnorris149 Sep 17, 2008
    My D80's built in flash was always a little finiky... sometimes I had to push it down a couple times to get it to stick... then it just decided to stay open one day. I will be sending it in under warrenty unless I can find a solution.
There is a small hex screw on the underside of the flash pop up... next to the latch. I gave it a half turn and presto... fixed...
Posted on Sep 26, 2008
    Problem Solver:
  • 7 Answers
I'm not sure of your problem, but if I understand it correctly, the flash does not pop down on its own, you just push it down and it locks down.
Posted on Jul 21, 2008
3 Suggested Answers
  • 7 Answers
SOURCE: Nikon D80 - My (built in) Flash will not pop up.
That is just a mechanical problem. There is just a little hook holding the flash and it retracts when you push the bottom to pop up the flash. I'm sure it can be easily fixed, never the less your camera store or Nikon should take care of it. So take it back to the place you bought it.
Posted on Aug 05, 2009
  • 181 Answers
SOURCE: Nikon D80 flash won't pop up
Must be a problem with the flash lock. Try to pop up the flash manually using the flash button located at the top left of the camera beside the flash. If this does not work, you may need to have the cam serviced
Posted on Jan 08, 2010
I have a Nikon D80 and I hit the open flash and now it won't flash. The flash will pop up but won't flash.
Contact your local Nikon authorized service center for repair on this issue. If you're in the east coast or in the New York City area you can contact us for this.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 06, 2011 | Nikon D80 Digital Camera
How do you turn off automatic flash manually on Nikon d80?
Assuming you're in one of the point&shoot modes (any mode other than the PSAM modes), press and hold the flash button on the front of the camera and turn the main command dial on the back to cycle through the available flash modes. To turn flash off, select the lightning bolt in a circle with a slash through it.
In the PSAM modes the flash will not pop up on its own.
Aug 22, 2010 | Nikon D80 Digital Camera with 18-135mm...
ERR message flashing. IT wont allow me to take anything
i had the same exact thing happen yesterday while shooting a wedding have NO idea why this happened, after my hsband running out and buying a new D 90 1,000 later my camers D80 is workking agin today???? did you find out why this happened to yours??? email back @ iamkelly@q.com Thank you I am going to takemine it to be serviced and cleaned mabe that seems to be the issue
Jan 29, 2010 | Nikon D80 Digital Camera with 18-135mm...
I was using the D80 with an SB-800 Speedlight and at one point the buit in flash popped up. I now cannot get the built in flash to lock in the down position.
This must be because the SB800 was not seated in properly or was turned off when you used the cam.
Use one of the manual settings (A or S) and you should be able to keep the built in flash down (unless it was physically damaged that u need to bring it to the repair shop)
Dec 21, 2009 | Nikon D80 Digital Camera with 18-135mm...
D80 SLR lens /flash prob lem
What are your other lenses? If they're not AF lenses, you're not going to get autofocus or metering.
Is your flash not working when popped up? Remember that the flash won't pop up automatically in Manual mode.
Oct 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Jun 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Jun 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
D80 flash doesn't close
erik, It's a little plastic arm with a tiny hook that moves to allow the flash to pop up when you press the flash button on the front of the camera or select the built-in flash option.  You may be able to get parts direct from Nikon or if you have a good local repair shop they may have a parts D80 to cannibalize for you if you have the skill to put it together.  If you got the camera at a good price and don't really rely on the built-in flash, (one on the hot shoe is always better) then tape that puppy down with some electrical tape until the repair is done and shoot all you want, peel it back for the pop up when you need a fill in flash or you don't have the flash with you.
randy320sgi
Oct 24, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 using Bower AF 724AFN
I also purchased a Bower 724AFN to use with my D80, and experience the same problems. Received confirmation from Nikon that this flash unit is not compatible with the camera. I then purchased an SB-600 flash, and haven't looked back. It's worth the extra money for this high quality unit; fully compatible, and compliments the TTL features of the D80. I'll never deviate from original Nikon accessories again.
May 22, 2008 | Bower (724AFN) for Nikon Flash
Nikon D80 Digital Camera with 18-135mm Lens Logo
683 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
