Question about Hunter Ceiling Fan Control Switch
I have a Hunter fan with a bowl type light fixture. The chain that controls the fan goes through two holes, one through the metal disc that the bowl sits against, and the other through a hole in the cap next to the finial. The problem is, the chain is always sticking because of the angle it has to take--even when I line it up as straight as possible. Any suggestions?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Either you take a glass drill and make the hole a little larger, or just to put a bevel on the holes, or take a candle/wax and rub on the chain, where it it goes thru the hole. last but not least, you can try to convert to a string,instead of a chain.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Bad hunter ceiling fan light pull switch
I don't know what you mean, longer stem/chain housing to hold light fixture. You should be replacing a two wire switch only.
Feb 15, 2014 | Hunter Dryers
I have a Hunter Ceiling Fan Model No. 27185. I can control the fan with the remote but can not control the lights with the remote. is there some instructions on how to operate the system?
27185 is the model # of the remote. Check to make sure your light wires are connected at the light fixture & receiver. Also, make sure your dip settings are set on the same frequency. Lastly, push the light button & pull the chain on the light.
Oct 06, 2013 | Hunter Dryers
When I pull the light switch chain on my Hunter ceiling it does nothing. No click, no light, nothing. Is there some part to replace?
First, you need to know if it's getting power still. if there's power to the fixture, you might need to replace the pull switch. The hardware carry's these part.
Sep 02, 2011 | Hunter Ceiling Fan Light Switch Control
Ceiling fan with light and remote: Globe came loose and fell down. Broke one of the chains and can't find where it goes. Can you help? It is a hunter fixture
The chain should go into a small hole on the housing that wraps around part of the motor. In order to connect the chain you will have to lower that portion of the housing cover some how. It should have a small portion of chain that you can still connect to. If it broke off inside the motor, you may not be able to fix that and may have to ask an electrician to the job, An electrician will be able to tell if you need a new fan motor or if it can be fixed. If you can take photos of it ( up close ones). You can email them to me and I may be able to assist you better.
Marc the Handyman
Marc Arel Services
mackeral74@hotmail.com
May 28, 2011 | Hunter 52" Ceiling Fan With Light And...
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
Why won't my remote for my light on the Hunter fan work? The light also will not come on when I pull the chain.
I usually discuss this exact problem with customers that have a DIY ceiling fan. First; If you just installed this fan you noticed that there are several switches on the fan and on the remote, there is also the switch that originally controlled the ceiling light fixture (If it is a dimmer switch, it MUST be replaced with a single pull switch). All of these can be set wrong. Make sure the circuit breaker is not "tripped."
To start easy; assure that the wall switch is on, (leave all the "pull chains" alone, for now) Check to see that the remote has fresh batteries. press the light switch (on the remote, if it is a dimmer type set it to high, press it several times. If this does not work leave all the switches where they are and pull the light chain once, and again try the remote for the lights only. Hopefully that worked. Now do the same for the fan, press the remote once (on any speed) If that does not work pull the fan chain once try the remote again pressing the same switch, that should work. Now that you have it working remove all the pull chains, so it won't get "confused" again. Good luck!
Feb 09, 2011 | Hunter 27185 Remote Control
I am attempting to install my Hunter 21095 Westcott fan and am unsure of the wiring. Power is at the ceiling fixture which in turn feeds the next rooms fixture and the switch wire is also in the ceiling...
Black is for the fan motor which you connect to black(hot), black/white is for the light which you connect to the switched lead in the ceiling, the white lead from the fan goes to the neutral lead in ceiling, and tjhe green wire is earth ground and goes to the box screw in the ceiling
Jan 20, 2011 | Hunter (25417) Ceiling Fan
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
111 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
