Question about Apple iPhone Smartphone
My iphone is not getting charged!! - Apple iPhone Smartphone
  • 3 Answers
Sounds like a hardware problem, bad charge port or battery, perhaps. Www.dancingcellphone.com offers mail-in iPhone repair services. $60 to replace your charge port if necessary. Try cleaning the port out with an alcohol-soaked toothbrush, allow time to dry and try charging again. Use 99% alcohol if possible.
Posted on Feb 17, 2011
    Novelist:
  • 141 Answers
Try charging your phone via wall and computer if - still no luck try a different charger - still no luck - then make sure you have the latest version of itunes installed on your computer and create a back up of your phone ( in itunes right click on your phone in devices, select back up) then once that process has finished restore your phone as a new iphone, then try to charge your iphone, if this still doesnt work check when you bought your phone as you may be covered by your warrenty to get it fixed.
** restoring your phone as new will wipe it completely it could be the software on the phone affecting it functioning correctly but if you want info back choose to restore your phone from a back up by selecting your phone from the device menu in itunes & click on restore from a back up and click the earlier you made.
Posted on Dec 29, 2010
  • Apple Master
  • 554 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Iphone won't charge unless it is completely powered off
Luckily, there are some tracks you can try to fix it.
iPhone wont charge when turn on
# Check Charging Accessories
# Clean Charging Port
# Hard Reset Your iPhone
# Using iPhone Recovery Mode
# Restore iPhone to Factory Settings
http://www.recoveryiphone.net/article/fix-iphone-wont-charge-when-turn-on.html
try practical methods to fix your problem, and if it still can't get your problem solved, just take it in for service at the nearest Apple Store in your area to get the help of the Apple employee.
Mar 20, 2013 | Apple Iphone 4s latest Model - 32gb -...
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
My iphone 4s will not charge
have a look at the port on your phone were u put the charging cord and see if the we part inside is broken or cracked and do the same on your power cord if u cant see anything wrong and u cheep u can always buy parts for them and take apart your iphone and replace the power socket
Aug 03, 2012 | Apple iPhone Smartphone
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
IPhone Smartphone: cant charge iphone in ibiza battery went flat...
Possible solutions
1. buy an adapter for your charger
2. plug it into a computer
3. provide more details than you have so far...
can't charge iphone is a vague way to explain your predicament...
can't charge or won't charge?
can't get an adapter?
don't have access to a computer?
Half solution, half clarification request...
May 16, 2010 | Apple iPhone Smartphone
Iphone not charging
Hi your iphone ribbon to charging connector a home button is damage, you will have to get it replaced for cheap repair prices check www.E-Repairs.co.uk
Jul 26, 2009 | Apple iPhone Smartphone
Iphone will not recharge Each time my iPhone 3G gets below 20% it will not accept a charge. I have to hook it up to my home computer and hard reset it until it decides to take a charge and be recognized...
it could also be that the iphone is too warm / hot. turn off the screen, lock it while it charges otherwise if the phone is too warm before getting charged the phone has a built in sensor that will stop it from charging until its cool enough to continue.. its a safety feature.
Nov 06, 2008 | Apple iPhone Smartphone
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Apple iPhone Smartphone Logo
531 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
