Question about Music
Cannot save the split keyboard settings - Music
  • Music Master
  • 5,603 Answers
With hundreds of keyboards that have split capability how are we to guess which you have to offer any solution?
Posted on Dec 29, 2010
Yamaha DGX 220 All E and Bb keys above middle C will not play. All others OK
Just a shot in the dark but a lot of keyboards allow for splitting the keyboard in half or even in quarters to assign multiple sounds... have you tried a total reset? Or explore the manual for setting up a split keyboard. Might help.
Oct 26, 2017 | Yamaha Music
Roland fantom g8, problem, The last 2 octaves do not issue sound
Read page 135 regarding the note range settings. Look also for keyboard split information. You may have the keyboard set to NOT play notes in the top octaves for the particular voice you are using.
Feb 23, 2011 | Roland FANTOMG8
When i press the "music data base" button, nothing
You have put the keyboard in "Split" mode. In this mode you can assign a different voice for the left hand than the right.
The F# is the standard point to split the keyboard voices.
In the music data bases often a "style" is selected and if you select ACMP accompanyment, when you trigger a chord on the left hand it MAY start the rhythm... If you want an additional voice on the left over what the style is set to, you may have to independently select it.
Feb 09, 2011 | Yamaha DGX640 Music Keyboard
I have a Casio Privia Px330. On a split keyboard how do I alter the right hand tone?
On page E11 of your manual... see the picture with two voices, one for the T and one for R... select them there.
Your manual can be downloaded here: http://support.casio.com/pdf/008/PX330E1A_web.pdf
You probably cannot "change the tone" of the two voices if they are the same voice. You should be able to transpose to different octave however.
Feb 03, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
PSRE323 - is there a way to specify what midi channel is used for midi out, how do you do it. Manual didn't seem to specify anything.
How they expect you to find the information is beyond me!!! I downloaded the manual and it appears that the information you want is on page 57.
Near the bottom, and the only way I spotted the parameter of MIDI channel number setting is seeing the range as 1 to 16.
They list this as L part and R part channel/track setting... these will be for the left and right parts of the split keyboard... that is you can set a MIDI channel to between 1 and 16 for both the left and right division of the split keyboard.
I don't think many people would find this... AND shame on Yamaha, there doesn't seem to be a MIDI implementation chart, which you should get familiar with for any MIDI devices you might have... the chart is a quick access to the MIDI capability of MIDI devices and they didn't include one in the documentation for this unit...
Dec 31, 2010 | Yamaha Survival Kit B2 for PSRE223,...
Can the casino CT655 keyboard be split
In a way the answer is YES... BUT ONLY some of the tones will split on the keyboard... and unlike the new conventions of splitting above F#2, the CT 655 splits at B2.
Read your user's manual on page 11.
Jun 16, 2010 | Music
My Casio CTK-496 Keyboard has three keys (2nd octave F sharp, G, and G sharp that don't play anymore. How do I fix this?
First make sure a keyboard "split" option is not set.
Probably you are going to have to clean the key contacts. They are likely conductive rubber "pills" that are pressed onto a circuit board that has interleaved fingers. Clean both the black pills and the circuit board using ONLY 99% isoprophyl alcohol and Q-Tips.
Feb 17, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
How to save setting changes on Casio WK-500 keyboard?
This is a link to WK-500 owners manual.....SD Card information is on pages E-59 thru E-64...
http://support.casio.com/pdf/008/WK200_500_e.pdf
Oct 22, 2009 | Music
Korg TR88 splitting the keyboard.
Read the manual if you've got it. If not get in touch with Korg.com and they should be able to tell you and you might get a manual download.
Good Luck
Aug 23, 2009 | Music
Split two hands for two different sounds
The SP200 does not have any built in ability to split the keyboard between high and low. My guess is that you were seeing someone using this keyboard as a midi controller for a sampler (or sample player) and they had assigned various samples to keys or key ranges. This can be done using Reason fairly easily. The setup would be in the sampler you use however and not the keyboard.
Hope this helps.
bd.
Jan 03, 2009 | Korg Pa800 Synthesizer
Music Logo
130 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
