Question about Marantz Audio Players & Recorders
I have a Marantz 6003 CD player purchased March 2010, which has been working fine. Recently it stopped giving any sound input but the display shows it is reading the cds, the same problem happens when I connect my Ipod. Thinking it could be my old amp faulty I purchased a new Marantz amp in Dec. For a few days all worked fine,but now the same problem has come back. It is not a amp problem because the turntable works ok through my amp. I have also upgraded the connection cables between the amp and the cd player. I took the cd player back to my dealer under warranty and yes it worked ok in the shop . I am at a loss what it can be, can you help
    Habit-Forming:
    New Friend:
  • 64 Answers
You sure its not your amp?
Posted on Apr 07, 2017
Benimur
  • 6966 Answers
SOURCE: TEAC H300CD Player
Hi, Your particular brand/model was made in the very early 2000. It is possible that the eye (optical lens) is already weak and would need replacement or calibration. You may want to try and clean the lens hopefully improving the reading capability. Some users of CD players use a PC CD cleaner to clean the eye (pls read the instructions) though this can be done by going inside the unit). Probably your best bet is to seek the services of a qualified professional. Hope this be of some help and give you ideas. Pls post again how things turn up and/or if you need further information. Good luck and kind regards.
Posted on Aug 04, 2007
TRocky
  • 4 Answers
SOURCE: Ipod Connection through RCA Cable
Actually, what I think gbaity is doing is utilizing his IP(Interactive Pioneer)-Bus port in the back of the DEH-P3000, which is an input port designed to allow the deck to use an external multi-disk CD changer. All you need is the CD changer, then change the input source from your deck to "M-CD". There are folks on eBay and other places that sell a cable that pluggs into that very same port. They are designed to allow the unit to accept input through the IP-Bus from an ipod or just about any low-level input that you can pass through the RCA jacks. I have the same deck, and also just purchased an ipod cable for the IP-Bus, and it also does not work. I have been told that I need to switch the "M-CD" input source to "AUX" as the input, but I do not know how to do that. pressing the input source button only displays "CD", "M-CD", and "FM/AM". Does anyone know how to add "AUX" to the choices or otherwise show us how to make these cables work? Thanks - TomR
Posted on Sep 23, 2007
likha
  • 790 Answers
SOURCE: my mpman mp3 player not working
maybe you have loose connection! at the port connection! you can re solder it!
Posted on Oct 10, 2007
  • 11 Answers
SOURCE: IPod Video 30 GB won't sync to itunes
  1. Okay you will have to Uninstall iTunes.
  2. Go to START CONTROL PANEL and ADD OR REMOVE PRGRAMS uninstal itunes.
  3. Go to apple.com/iTunes.
Posted on Nov 29, 2007
SOURCE: Computer doesn't recognize unit when connected
Hi All,
I had the same problem and was going crazy trying to figure this out, but I found that I had installed the GPX mw3816 on my bottom USB port and was trying to plug it into the port above it, because I had plugged another unit into the bottom port, but I switched the ports and it immediately installed. This is another reason, I am thinking of dumping windows and moving to a MAC. Peace!
Posted on Jan 04, 2008
Marantz how to connect 6005 amplifier to ipod
There are many solutions, I show two. The tip photo, shows a more expansive one. the lower photo the cheaper one. But both have two tulip plugs on the side for the amplifier and one 3,5 mm stereo telephone plug to the other side.
I tried both on a good stereo set, and could not hear different quality in sound. My guess, the quality comping from my iPods, iPhone and iPad is not the same as from my CD player. On the CD player, a better cable proved to give a better sound.
c25e6b72-61d1-4158-8864-9fee0335d5fc.jpg 0c90f720-e235-4415-a30c-8a9f98411676.jpg
May 26, 2014 | Audio Players & Recorders
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time...
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Feb 11, 2014 | Marantz CD5001 CD Player
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
MY MARANTZ CD-5001 PLAYS FINE WITH ANALOG CABLES, BUT THERE IS NO SOUND WHEN I USE DIGITAL CABLES.
Well, we would need to know tyo what it is attached and that it is correctly configured to reproduce the digital input from the CD player. Have you triee BOTH optical and coaxial outputs?
Dec 13, 2010 | Marantz CD5001 CD Player
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Aug 11, 2009 | Marantz DV-9500 DVD Player
Marantz SA-1 installation question
Does your Marantz have an "optical" or "digital" out?
If so, use them. Assuming you have a quality receiver/pre-amp/amplifier it will have it's own D/A converters.
If you plug into the receiver's CD inputs you will be using the D/A converters in the Marantz.
If you plug into the DVR/SACD inputs - it depends on the receiver et al.
Try both. See if one sounds better. Select the one that sounds best. For a top-notch system you need high quality from cables to receiver, and speakers. You system can only be as good as your weakest link, so what sounds good/great to your ears, that is the best!
Cheers
Mar 27, 2009 | Marantz SA-1 CD Player
I like the look and price of the Marantz SR 6003 receiver, my only question being whether it suppports DSD data output from a SACD player like the ONKYO like the OPPO DV-980h. In other words can it receive...
Downloaded the user manual for the Marantz SR 6003 A/V Receiver. In this it stated that if a SACD player was connected to the SR 6003 with an HDMI interface earlier than 1.2 then the digital data from the SACD could not be transferred over the HDMI cable to the SR 6003. This implies, but does not confirm, that if a SACD player does provide a digital output on an HDMI 1.3 interface, then SACD audio data can be transmitted to the SR 6003 and, presumably, decoded and converted to 6 analogue streams which are then amplified and deleivered to the (6) analogue output terminals.
I'm fairly sure that the native DSD data from the SACD has to be converted to PCM before transmission over the HDMI interface which is better than nothing. What I was hoping for though was for the data to be transferred in DSD and converted in the SR 6003 directly to analogue, avoiding two intermediate conversions. This ideal solution can be done by only a few SACD/ A/V Receiver combinations, which is silly considering that it is also the simplest. One example, which has made a big impression amongst high fi enthusiasts, is the OPPO DV-980H Universal DVD player (plays any audio or video disc and costs almost nothing) and the Integra DTC 9.8 home theatre processor.
Jan 14, 2009 | Televison & Video
67 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
