Question about Vacuums
I have an error code of E42 on my Samsung Cm1929 1850 W microwave
  • Barrett Palumbo
    Barrett Palumbo Dec 29, 2010
    Sorry to hear about your issue.
    But you have entered your problem, in the wrong area.
    Example: I have a broken PC, and its posted under ovens.
    In addition, please give the make and model of your unit.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
The code means you have a defective relay on a control board, Hence you need to have a board replaced. You do have a expensive unit, I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
I have a kenmore elite microwave oven model 363 63692301 stoped heating food ;. fan & turntable work. HELP!
Hello, two things. The mega-tron tube is gone south, or the HV diode is open/shorted to ground which will cause to open. If the microwave meta-tron tube is bad then recyle your microwave oven and buy a new microwave oven. One can buy a new microwave oven cheaper than buying a microwave tube. GB...stewbison
Sep 12, 2011 | Vacuums
Getting an H97 error code on a Panasonic micro wave, I believe I am having an inverter problem
Troubleshooting of Inverter Circuit (U) and Magnetron
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
NOTE: DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
Alternative way to troubleshoot oven with AC Ampere meter used. H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation with AC Ampere meter used for troubleshooting.
Hope this helps.
Apr 28, 2011 | Vacuums
F-4 error code on microwave
what kind of microwave is it?
Jan 29, 2011 | Vacuums
I have a Kenmore Elite Ultrawave Microwave Hood Combination and am getting an F9 fault code. I hear a rythmic intermittant buzzing, the unit shuts off and the F9 appears on the screen. I have pulled open...
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Nov 01, 2010 | Vacuums
Trying to purchase an Emerson microwave splatter shield replacement part. Cannot find a vendor to purchase from. MODEL #MW8992RD
EMERSON MICROWAVE-IF THE SHIELD (METALLIC CARDBOARD THEY CALL SPLATTER SHIELD) IS BURNT OR HAS BLACK SPOTS THROW THE MICROWAVE AWAY. MY SHIELD CAUGHT ON FIRE. MICROWAVE ONLY 3 YEARS OLD. DON'T BUY EMERSON.
Sep 22, 2010 | Vacuums
I have an Amana above range Radarange, Model #AMV4204AAB, Serial # 10168958GE. Tonight after running for a 7 minute period and finishing, it would not again start. There is power to it, but various...
  1. Push the power cord all the way into the outlet in case it became loose and is causing the problem. If the microwave still isn't working, check for a blown circuit fuse, and repair it.
  2. Step 2 Check that the controls on the microwave are programmed correctly according to the owner's manual. If they aren't, program them.
  3. Step 3 Close the microwave door firmly. Touch the cook function on the Start Pad, not the timer. Check if the microwave works. If not, continue to step 4.
  4. Step 4 Program the Power Level correctly. If it's not programmed properly, the microwave will cook the food too quickly or too slowly.
  5. Step 5 Use only microwave safe dishes. Make sure food is evenly shaped and defrosted before placing it in the Amana Radarange microwave.
Thanks.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 09, 2010 | Vacuums
Vacuums Logo
1,236 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
