Question about ASUS motherboard P5S-MX SE LGA775 SiS671FX Dual core / Core2 Duo PCI-E integrated VGA micro ATX P5... (4719543152454)
I'm planning to upgrade my desktop and i want to start upgrading from cpu. My current motherboard is Asus P5S-MX SE and cpu is Intel Pentium Dual Core Processor E2160, 1.8Ghz. Can you give me a list of compatible processor(w/ its speed indicated) to my current motherboard used? And please select the one you preferred the most. Thanks a lot! Jasper.
    Problem Solver:
  • 13 Answers
Oh boy, you're in the same boat i'm in with my dad's HP asus based OEM board. You're max choice in a regular core 2 duo is the E6700 @ 2.66ghz with a 1066 FSB (Front side bus). Reason being is likely identical to my situation. The board likely only supports a "conroe" core. It can't handle the "WOLFDALE", otherwise they would list higher ghz for an E6700. The E6700 is also available as a 3.2ghz with 1066mhz FSB, but its based on 45nm process, which requires different power regulation from the board. if you were to put in the wrong chip, you get nada. Not even POST errors from what i've read where others have tried and failed.
Unfortunately, E6700 @ 2.66ghz are a little rare, but they are on ebay for about 80-100 bucks, and various other places. Search for "E6700", but be careful to avoid the 3.2ghz's.
The only other choice for max is the Core 2 Extreme X6800 @ 2.93 ghz. This processor looks like its about double the cost to the E6700 though. That's a lot of extra money to get only .27 gain in ghz though, IMO, though there could be other reasons to go extreme, like availability. There might be more of them! The same logic applies here. Stay with the 65nm process, and 1066 FSB.
Here is the tech spec page for your board. Its shows all the supported processors: http://usa.asus.com/product.aspx?P_ID=fLSzpcTDJYT0rgS6&content=specifications
You might want to choose carefully on whether to upgrade this board's CPU. Might be time to scrap the whole board and get something with more FSB capabilities.
Posted on Dec 29, 2010
Hi i using ASUS P5GV-MX Motherboard i want upgrade processor so kindly give me specifications
Hello take a look here at the homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GVMX/#CPUS
Here is the list of supported cpu for the mainboard.
Your mainboard use Socket 775 for Intel Pentium 4.
This cpu type is phased out.
But you can always look for a used one.
You maybe have to upgrade the bios to support a bigger cpu.
Hope this was helpfull
Nov 18, 2012 | ASUS P5GV-MX Motherboard
Sir can i change my processor to dual core using this asus p5v800-mx?
Dear sir,
Deffinately This Mother Board supports Dual core 2ghz-2.8Ghz And Pentium D 3GhzProcessors.You can Upgrade your PC.
P5V800MX motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Enjoy the extraordinary CPU power from the latest dual-core CPU.
Aug 04, 2009 | ASUS P5V800-MX Motherboard
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
I can't work out what size chip to put on my motherboard
Asus list supported CPU's for your P5S-MX SE Mb.
Click on the link below;
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S-MX%20SE&product=1&os=17
The further down you go the stronger the CPU.
When looking for the CPU that you want, you'll also need the bios version listed across from that CPU.
The next link will list everything pertaining to your Asus board.
Look to the left for more information like FAQ, supported CPU & Forms.
(For the link below to fulley open, you'll need to choose your operating system from the drop down menu & click Search in order for the driver link to load);
http://support.asus.com/download/download.aspx?modelname=P5S-MX%20SE&SLanguage=en-us
Use the manual to help you. (Download it needed).
BIOS 0306 is the latest revision & supports the newer CPU's.
Pentium Dual Core E2220(2.4GHz,800FSB,L2 1MB,M0).
Link to some CPU's;
http://www.google.com/products?hl=en&ei=oZEIStOIMpuWMdmEmcwE&resnum=0&q=Buy+Pentium+Dual+Core+E2220(2.4GHz,800+FSB,L2+1MB,M0)&um=1&ie=UTF-8&ei=qJEISshJj7402Mno2AI&sa=X&oi=product_result_group&resnum=4&ct=title
Cheers!
Mike
May 11, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
I carnt work out what size chip to put on the p5s-mx se Socket LGA775 motherboard
Ok no problem I can help you there. First you want Intel or AMD. I would take Intel. Then you want Core Duo or Core 2 Duo, I'd take Intel Core 2 Duo, then you need to find out the Frontside Bus Speed of your motherboard, it has to match the CPU. So let's say its 1,066MHz. And you want something faster than 1.8 so go with 2.4GHz. So now we looking for a Intel Core 2 Duo, 2.4GHz, 1066MHz bus speed with stock cooler. So then go to www.intel.com, in their search box type "Intel Core 2 Duo 2.4Ghz" and it will bring up all the CPU's and their prices..if you have any questions let me know. Pls rate this solution.
ASUS P5VD2-MX SE Motherboard CPU compatibility
Hello itsme99, click on this link I have posted. This link shows what CPU you're Asus P5VD2-MX SE motherboard can run.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5VD2-MX%20SE
You're board does not support Quad core CPU's!
This next link is the main page (Drivers, FAQ's ect.) for the Asus P5VD2-MX SE motherboard. (Look to the left of the page under Related Link). http://support.asus.com/download/download.aspx?modelname=P5VD2-MX%20SE&SLanguage=en-us
Here is a list of Asus Quad core motherboards.
http://event.asus.com/mb/quad_core/
Have a nice day.
Enjoy!
M
Jun 06, 2008 | ASUS P5VD2-MX SE Motherboard
ASUS motherboard P5S-MX SE LGA775 SiS671FX Dual core / Core2 Duo PCI-E integrated VGA micro ATX P5... (4719543152454) Logo
222 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
