Question about Philips 170B5CB 17" LCD Monitor
Meu monitor philips 170S esta ligando, mas apaga logo em seguida. Então tenho que ficar ,ligando e desligando ele se quiser ver alguma coisa. Alguém pode me ajudar?
5 Suggested Answers
jemthy
  • 176 Answers
SOURCE: monitor philips 170s
Maybe the brightness and contrast control is not working . If you can open you monitor cover or housing try to adjust the screen control in the back of the plyback usually the plyback is in the back end of the board monitor. there is two hole adjustment the upper one is for the screen adjustment and the lower one is for the focus try to rotate or adjust the two but be careful to touch other part of monitor specially the yoke or the picture tube.
Posted on Apr 16, 2008
kevin000
  • 1847 Answers
SOURCE: cd de intala??o
You will need to go to www.driverguide.com, register, and then do a search for 'J44414' dowmload and install.
Hope this helps
Posted on May 30, 2008
SOURCE: placa pci philips saa7130
mkighbk
Posted on Sep 23, 2008
  • 109 Answers
SOURCE: my philips lcd monitor in side dim please healps
It sounds like the backlight has gone out. Replace the monitor.
Posted on Feb 06, 2010
Mi monitor parpadea y no arranca ? que debo hacer tengo conocimientos de electronica pero no se que hacer
Primero verifica la luz frente a tu monitor si la misma esta parpadeando o de color anaranjada hay un problema con la tarjeta de video de tu computadora. Si esta verde esta recibiendo señal de tu tarjeta de video. La mejor forma de saber si tu tarjeta de video esta funcionando correctamente es utilizar otro monitor que sepas que esta funcionando correctamente y conectarlo a la computadora. Si funciona bien, tu monitor esta dañado. Mi recomendación es compra uno nuevo por que es mas economico que repararlo.
Mar 03, 2011 | LG Office Equipment & Supplies
Gostaria de instalar o software de driver do dispositivo
Já tentou usar o cd do dispositivo ou então no site do fabricante. Se for daqueles tipos Plug and Play ele automaticamente irá pedir o CD na primeira vez que você plugar. Se não aparecer, instale com o CD do dispositivo:
1- Geralmente ao colocar o CD, aparece uma caixinha com passos a serem seguidos do tipo próximo ou next;
2-Você pode ir apertando nos botões proximo(ou next) sem precisar alterar nada pois o padrão já instala certinho, ou se quiser pode alterar algumas coisas durante esse processo de instalação, a sua escolha ;
3- No final aparecerá que o processo foi concluído com sucesso, se não mande a mensagem para cá de erro;
4- Caso conclua com sucesso, verifique se o dispositivo foi instalado ao acessar o gerenciador de dispositivos: Painel de controle-->Gerenciador de Dispositivos;
4.1- Ou então por meio do atalho devmgmt.msc, no executar (acesso por meio das teclas windows+R);
5-Depois tente colocar o dispositivo na máquina.
Estas instruções servem apenas se o sistema for uma das versões do windows.
Mar 01, 2011 | Computers & Internet
Boa noite estou descarregando o aparelho mas esta dando erro na transmissa digite enter, mas nao sai disto preciso descarregar ja troquei a bateria qual a solucao?:
Boa noite
Eu tenho um igual e de vez em quando acontece-me o mesmo, como consigo resolver a situa??o, ? precionar a ficha RJ enquanto o PDT est? a transmitir para o PC.
Se pretender tocar mais ideias o meu mail:arlindopolicarpo@hotmail.com
Jan 16, 2011 | Symbol PDT 3100
Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Dec 31, 2010 | Kodak EasyShare V610 Digital Camera
Meu telefone perdeu todas as funções gostaria de rest, ou não sei se da pra formatar ou fazer o bot que nem o pc. Não sei mais que faço.
Alo grande.
Em primeiro lugar, eu so formatei ate agora Nokia 6600 e nokia N73 com os mesmos codigos.
Mas tu podes usar o mesmo codigo para alguns outros telemoveis.
Faca o seguinte Apos carregar bem o cellurar.
1 _ desliga o celular
2 _ volta a ligar o celular.( em seguida pressione logo nas seguintes teclas: Verde de atender, tecla 3, e tecla ASTERIX *. tudo ao mesmo tempo...) ate sair um sinal k seu celular esta ser formatado.
Se nao der, digite os seguintes codigos.. *#7780# ou *#7370#
Boa sorte
Nov 25, 2010 | Computers & Internet
Como consertar meu daihatsu terios l999
siga a mangueira da agua ate chegar a cabeca do motor nessa parte onde a mangueira conecta esta o termostato so tirar os parafusos
Dec 31, 2008 | Daihatsu Charade Cars & Trucks
Compaq nc 8430 keeps going into powersave mode when in docking station
eu tenho um computador portatil modelo 8430 mais so que eu quero instalar um outro windows mas ele esta a recusar é por isso que me levei a enviar este mensagem para perguntar se a um oureo soluçcão para ele
Oct 07, 2008 | HP Computers & Internet
Recording
Grupo: Participantes
PLACA DE PCTV ENCORE....?
Meu PC e windows xp...Ele é da microboard...., vem com 1gb 160Hd placa de pctv, AMD... Mas desde quando liguei meu PC pela primeira vez com o vista, não funciona a placa de pctv, depois que eu formatei, e instalei o xp, continuou não funcionando...já tentei de tdo, e naum sei mas o que fazer....
Tenho o programa ENLTV, que veio junto com a placa de pctv que é da ENCORE... quando tenho abrir este programa aparece um erro assim: " Fail to Initialize hardware!ErrorCode#E0601009 "
E no gerenciador de dispositivos, o driver " Controlador de Multimídia " com um ponto amarelo de exclamação..! Tento atualizar o drive com os cds que vieram junto com meu PC, mas nao adianta, já desistalei o drive, e reiniciei o PC, o drive foi reconhecido novamente, mas nao sumio o ponto de exclamação...
Jun 14, 2008 | Encore ENLTV-FM (EN-LTVFM)
Fone de ouvido
Não tenho certeza se eu entendi como eu não falam Português, mas, se eu sou, então você está perguntando qual a cor auscultadores em ir? caso em que, headphones e alto-falantes sempre ir para a luz verde jack. My reply in English; Not sure if I understand correctly as I don't speak Portuguese, but if I am, then you're asking which colour the headphones go into? in which case, headphones and speakers always go into the light green jack.
May 25, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Philips 170B5CB 17" LCD Monitor Logo
358 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
