Question about Verbatim CD-RW Rewritable Discs, Branded Surface, 700MB/80Min, 24x, 10/PK, Matte Silver - VER95174 (50023942951747) Media
How do I reuse a cd-rw disc over and over again.
  • 37 Answers
Insert your cd-rw into your computer and then:
- Go to My Computer
- Right Click on the drive (in which you have just inserted the cd)
- Click Format
Wait for it to format. Then you can reuse it again.
Posted on Dec 29, 2010
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
Mar 07, 2016 | Televison & Video
Tip
How to Erase a Burned CD
CD-RW stands for CD re-writeable. This type of disc can be written on or "burned" multiple times. However, in order to burn music or data onto a CD-RW that already has something on it, you must first erase the current contents of the disc. No special software is needed to do this, as you can do it with the Windows Media Player program, which already comes installed on all computers with the Windows operating system. Regular CD-R discs cannot be erased or reused--the discs must be labeled as CD-RW.
Instructions
Step 1.
Click on the "Start" menu button in the lower left-hand corner of the screen. Select "Windows Media Player" from the pop-up menu.
Step 2.
Select the "Library" tab in the main Windows Media Player screen.
Step 3.
Insert the CD-RW that you want to erase in the CD-ROM drive. Close the "AutoPlay" window if it appears.
Step 4.
Right-click the CD-ROM drive in the "Navigation" pane on the left side of Windows Media Player. Select "Erase disc" from the drop-down menu. This will automatically erase the contents of the disc.
on Jul 17, 2010 | Computers & Internet
My recorder will not finalize it says "Incomplete"
could be bad dvds. if you have a tv top dvd recorder they are bad about going bad, because theres not enough vent holes, recorder gets to hot, burns up. i put more vent holes in top of my case. your best bet is to get dvd rw's they work better. then take your pc and copy your shows on a regular dvd . then reuse the rw's for your next job.
Oct 03, 2013 | Sony RCD-W500C 5-Disc CD Recorder
'Writing Error' during last stages of burning a cd.
could be bad cd's ,but id say your recorder is going bad. you can try cd rw disks they work better in this case. then use a pc to copy to regular cd then reuse the cd rw disk again.
Sep 26, 2013 | Marantz CDR420 CD Recorder
Reuse cd rw
CD-RW. CD-R=CD Read only. CD-RW=CD Read & Write. There is a limited number of times you can write over on a CD-RW disk.
hope it helps
Nov 17, 2011 | Computers & Internet
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Have disks with old data and need to erase them. I have the Memoex cd-rw and Sony cd-rw disks. I would like to reuse them. I have an Aspire 3680 computer.
Copy all your data into the computer as backup and format the disk with old data, this will completely erase the old data and u can now reuse them whenever you want to from the computer or you can write them into cd through your memoex cd-rw or sony cd-rw. thanks
May 12, 2010 | Electronics - Others
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
Electronics - Others Logo
104 people viewed this question
Top Verbatim Electronics - Others Experts
Are you a Verbatim Electronics - Other Expert? Answer questions, earn points and help others
