Question about GE 24 in. Profile PDW8280JSS Built-in Dishwasher
My dishwasher barely cleans my dishes. i basically have to wash them before i place them into the dishwasher. also, once they come out there is usually residue of the dishwashing detergent especially on the top rack. another problem is that the wheels on the bottom are all warped and come off every time i use the machine. we have had this appliance not even for 5 years and it is driving me crazy! any advice/ solutions would be very helpful.
  • Ron Lyda Dec 29, 2010
    sounds like the pump or drain is stopped up. is there water in the bottom after the Cycle is done?
  • 101 Answers
Sounds like the pump or drain is stopped up. is there water in the bottom after the Cycle is done?
Posted on Dec 29, 2010
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Whirlpool Quiet Partner 2 dishwasher
You need to clean the 2 rotors properly and that also includes the sieve. Make sure once the dishes are stacked, the rotors must turn freely by hand.
Sep 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Kitchenaid KUDP01 not cleaning dishes
Remove the accumulator assembly and check the chopper to see whether it's clogged or damaged.
Jul 02, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dish washer won't wash dishes.
Remove the screen below the spray arm and clean the sump.
Replace the impeller kit on the motor shaft.
Clean debris out of the holes in the spray arm.
Feb 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher
basic checks:
is water entering into the machine.
is it hot.
is it being heated during pre-wash
is the soap being dispensed
is the pump running when cycling?
do the arms turn freely?
you mentioned the top and bottom shelves. are there places where the dishes 'are' being cleaned?, or are you meaning that in general they are not being cleaned at all?
most of the above indicators are observable by stopping the wash cycle from time to time in various modes.
to see if water is being pumped at all, put a bowl on the top and bottom shelf, and nothing else. if there is water in it after it cycles then the pump is moving at least some water.
start with these observations and please report back
good luck
mark
Dec 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
GE 24 in. Profile PDW8280JSS Built-in Dishwasher Logo
131 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
