Question about Pinnacle Dazzle DVD Recorder
Valid input signal not detected - Pinnacle Dazzle DVD Recorder
  • 101 Answers
1 unplug Dazzle from USB. turn off pc, restart with out dazzle plugged in. shut down PC, restart then plug dazzle in after PC has restarted fully. if that don't work then go to step 2. ( sometimes using a different USB port works too)
2. uninstall it and reinstall it should work fine. i had the same problem and had to many things in the USB ports at the same time.
Posted on Dec 29, 2010
Sometimes my 2001 Chevy Tahoe has no power at all nothing, then everything goes back on then it will start
How are battery an connections ? Do the headlamps work when this happens ? How familiar are you with the electronic on your vehicle ?
This could be an ignition switch problem , a BCM - body control module , The ignition switch is a Discrete Ignition Signal to the vehicle BCM body control module . The Body Control Module (BCM) performs multiple body control functions. The BCM can control devices directly connected to its outputs based on input information. The BCM evaluates this information and controls certain body control systems by commanding outputs on or off. The BCM control inputs can be:
GM has had a problem with ignition switches , but the thing to do is hook up a scan tool an check for the correct power mode .
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The BCM receives 2 signals/circuits from the ignition switch. These are the Ignition 1 and Ignition 3 signals/circuits.
To determine the correct power mode the BCM uses:
The state of these signals/circuits, either switch closed (B+ = 1) or switch open (open = 0)
The status of the engine run flag.
The chart indicates the modes detected and transmitted by the BCM:
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the "RUN" power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
You may want to take this to the repair shop an that doesn't necessarily mean the dealer !
Jun 29, 2014 | 2001 Chevrolet Tahoe
Which codes (OBDI or II) do I use for my 1994 Jeep Grand cherokee laredo 4.0 2wd
before 1996 they use onboard diagnosis system for jeep.
when you turn on key you need to count check engine light blinks.
here are codes taken from internet.
11* No crank reference signal detected during engine cranking.
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
13** No difference recognized between the engine MAP reading and the barometric (atmosphereic) pressure reading at start-up
14** MAP sensor input below minimum acceptable voltage.
or
MAP sensor input above maximum acceptable voltage.
15** No vehicle distance (speed) sensor signal detected during road load conditions.
17* Engine coolant temperature remains below normal operating temperatures during vehicle travel (thermostat).
21** Neither rich nor lean condition detected from the oxygen sensor input.
or
Oxygen sensor input voltage maintained above the normal operating range.
22** Engine coolant temperature sensor input above maximum acceptable voltage.
or
Engine coolant temperature sensor input below minimum acceptable voltage.
23** Intake manifold air temperature sensor input above maximum acceptable voltage.
or
Intake manifold air temperature sensor input below minimum acceptable voltage.
24** Throttle position sensor input above maximum acceptable voltage.
or
Throttle position sensor input below minimum acceptable voltage.
25** A shorted condition detected in one or more of the idle air control motor circuits.
27* Injector #1 output driver does not respond properly to the control signal.
or
Injector #2 output driver does not respond properly to the control signal.
or
Injector #3 output driver does not respond properly to the control signal.
or
Injector #4 output driver does not respond properly to the control signal.
or
Injector #5 output driver does not respond properly to the control signal.
or
Injector #6 output driver does not respond properly to the control signal.
33* An open or shorted condition detected in the A/C clutch relay circuit.
34* An open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
or
Speed control switch input below the minimum acceptable voltage.
or
Speed control switch input above the maximum acceptable voltage.
35* An open or shorted condition detected in the radiator fan relay circuit.
41* An open or shorted condition detected in the generator field control circuit.
42* An open or shorted condition detected in the auto shutdown relay circuit.
44* An open or shorted condition exists in the engine coolant temperature sensor circuit or a problem exists in the PCM's battery temperature voltage circuit.
46** Battery voltage sense input above target charging voltage during engine operation.
47** Battery voltage sense input below target charging voltage during engine operation. Also, no significant change detected in battery voltage during active test of generator output.
51** Oxygen sensor signal input indicates lean air/fuel ratio condition during engine operation.
52** Oxygen sensor signal input indicates rich air/fuel ratio condition during engine operation.
53* PCM internal fault condition detected.
54* No fuel sync (camshaft signal) detected during engine cranking.
55* Completion of diagnostic trouble code display on the malfunction indicator lamp (check engine lamp).
62* Unsuccessful attempt to update SRI (service reminder indicator) miles in the PCM EEPROM.
63* Unsuccessful attempt to write to an EEPROM location by the PCM.
* - Check engine lamp will not illuminate at all times if this code was recorded. Cycle ignition key as described and observe code flashed by check engine lamp.
** - Check engine lamp will illuminate during engine operation if this code was recorded.
PCM = Powertrain Control Module (the engine computer)
MAP = Manifold Absolute Pressure (the sensor that measures how hard the engine is sucking air through the intake manifold
EEPROM = Electrically Erasable Programmable Read Only Memory (a type of computer chip used inside the PCM)
Nov 19, 2011 | 1994 Jeep Grand Cherokee
I have 21 GOODMANS LD2212 TVs and want to play an MP3 player through the "audio in" however it shows no AV signal (yes I have selected AV or SCART source) likewise if I use a scart and connect...
From your description, it seems like the set doesn't activate the AV input unless it sees a video signal. I don't know if it the input is smart enough to require a valid composite signal (that is, one from a source that includes proper synchronizing signals) or if it will work as long as something is there. So here's a suggestion. Get an RCA Y-adapter with one jack in and two plugs out, and split one of the audio outputs from the MP3 player. Feed the audio to the audio input as normal, and connect the other plug to the video input. This may enable the AV input since there will then be some signal at the video input. It won't be a valid video signal, of course, so if it works you'll just see random flashing on the screen. Maybe you can pretend it's a light show to accompany the music.
Mar 30, 2011 | Goodmans Televison & Video
Hi my 2006 cadillac cts has error codes po 300 303 305 343 347 368 392 and 496 can u tell me what they are or a website to find out thank u
P0300 is multiple engine misfire detected
P0303 is misfire in cylinder 3
P0305 is misfire in cylinder 5
P0343 is camshaft position sensor A (bank 1)
P0347 is camshaft position sensor A (bank 2)
P0368 is camshaft position sensor B (bank 1)
P0392 is camshaft position sensor B (bank2)
P0496 is EVAP Canister Purge System High Purge Flow
Jan 28, 2011 | 2006 Cadillac CTS
How do i switch my monitor to vga input?
Plug in the VGA cable to the monitor, and to the computer.
The monitor automatically determines which inputs have a valid signal source.
You can also set the monitor's source of video input to VGA, by going to the On Screen Display menu, and the Switch Video Input option.
Here is the User Manual,
http://h10032.www1.hp.com/ctg/Manual/c00834092.pdf
If you have questions post in a Comment.
We'll step by step you through it.
Regards,
joecoolvette
Dec 17, 2010 | HP w2207 Monitor
It says an invalid input signal has not been detected.also the cables are in correctly and another problem there's no picture in the preveiw screen
Welcome to Fixyah,
Here check this link
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=213159&Hilite=invalid+signal+has+not+been+detected
Jul 05, 2010 | Pinnacle Dazzle DVD Recorder
Keep getting message - a valid input signal has not been detected. Please check your cables.
Hi and Welcome to FIxyah.
When you see that kind of message all you have to do is to turn your camcorder,vcr,VHS, then after that hit play button, now check if the said error message come out again.
Now make sure that the video preview showing your video and if there is no video showing you must check you video connection.
Feb 27, 2010 | Pinnacle Dazzle DVD Recorder
Tom tom one wont detect gps signal
my tomtom wont get a signal and is saying are you in a building?
Jun 18, 2009 | Tomtom ONE GPS Receiver
US-1641 audio interface "no valid signal"
check the console in control panel and assign the ports ur using.
Jul 16, 2008 | Tascam US-1641 Sound Card
Pinnacle Dazzle DVD Recorder Logo
1,799 people viewed this question
Top Pinnacle Computers & Internet Experts
Alun Cox
 Ian Kayhan
Ian Kayhan
Josh Levin
Josh Levin
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
