1977 Pontiac Catalina heater problem The core is new, the radiator is new, the heater motor is new, but still no heat.
  • 101 Answers
Is the deverter valve opening to let hot water to flow through the heater core. this seams to be the most likely problem. unless the water inlet / outlet going to or from the heater core lines is stopped up.
Posted on Dec 29, 2010
Testimonial: "I will get back to you tomorrow. This is about the heating problem with the 77 Pontiac Catalina."
  • 1 more comment
  • ltbept Dec 31, 2010
    Thank you for your advice! The new deverter was ordered and installed last week and the heater core was installed (new) the day before. The deverter had to be sent (next day) UPS. The heater worked two days but now is blowing cold air again. I am extremely unhappy! El Paso, Texas has mechanics that keep customers going back and forth, because they never completely fix the problems. This is a trick to always have a garage with cars parked all over, so people think that the mechanic is real busy and must be good. Otherwise the mechanic would not have so much apparent business. BS!
  • Ron Lyda Dec 31, 2010
    I am Sorry the people at that place is Doing you that way. I want you to know we here at fix ya are not in no way the same.
    the only things left on your car is the vacuum lines of valve that moves the deverter valve. and on your dash there is a control it is the one that is red and blue you choose to be hot air or cold air. if in fact this is vacuum this controls whether the valve is open or closed. in some cases this is an electrical valve. it is easy to tell by looking at the valve. if it has a place for a small vacuum hose(s) to push up on it its vacuum. if it has a electrical plug its electric. keep in mind there can be wires to run the lamp that illuminates the back of it, when your lights are on. if you have a vacuum leak in your system as will. the Deverter valve might work part of the time. if you need any help please get back to us we would like to help you get this fixed.
    Thanks very much for the opinions on the heating problem with the 77 Pontiac Catalina. I will get back to you tomorrow,
Which hose goes where on my 2000 pontiac sunfire heater core...
are you installing the correct thermostat the right in the head or block
3 thermostats indicate incorrect fitment method
heater hoses run either way as the water is pushed through the heater core by the pump
Apr 21, 2017 | Cars & Trucks
Heater core
heater core is spraying coolant because there is a line connected to your heater core that comes from your radiator witch is how your heater core gets its heat to defrost windows or heat your car via your motors coolant temperature that is why heat in your car is not instant when you turn it on and you have to wait for a min or two
Oct 18, 2012 | 1998 Pontiac Grand Prix
I put coolant in radiator and I get a/c but my heat doesn't work. I think my heater hose was bypassed by the previous owner. How do I fix the problem?
You should be able to look down in between the motor and the firewall and see if the heater hoses are attached to the heater core. Most of the time when they are bypassed it is because the heater core has started to leak. Instead of replacing the heater core (not a fun or easy job) they just bypass it so they won't leak coolant. So, if it is bypassed your probably looking at replacing the heater core in order to get heat.
Nov 09, 2010 | 1995 Pontiac Grand Am
I have a 1977 firebird with no heat coming from the heater
sound like you have a clog in heater core or water valve (if it has one ) need to take off heater hoses and make sure it flows thru flush with water hose
Nov 25, 2009 | Pontiac Firebird Cars & Trucks
I have a 2002 pontiac firebird v-6 3800. The heater hoses run into a part that is attached to the motor. I am trying to find the name of the part so I can replace it or find an engine diagram for that...
Paul, if you mean "radiator hose" then the part is the thermostat housing.
Perhaps the part is the bypass valve, which causes the heated water to "bypass" the heater core if the core is restricted.
Sep 28, 2009 | 2002 Pontiac Firebird
1999 pontiac sunfire over heats vents blowing cold air
Take the inlet & outlet hose off of the lines feeding your heater coil, where it come off the motor. Do you have good pressure on your water supply to your house????? If Yes. Flush the water thru the heater hose backwards from the diterction that the water normly flows from your car motor. Alot ot the time your heater core will just be plugged up and need to be backflushed. Also make sure that you do not have trash/ leaves in your heater box?????
You can also later on after flushing the H-core out, you can flush your motor, radiator & heater coil by dropping everything out and add water plus 1-can of old style Comett. This is very abrassive!!!! Run the motor for about 1-hour. Then drop all of it out. Put just water back into the system and run again about 10-minutes.Do this flushing about 3-times. You will see how clean your radiator will be, plus the cooler your motor will run.
Feb 03, 2009 | 1999 Pontiac Sunfire
1994 pontiac firebird HAS NO HEAT
Okay. warm up vehicle, get radiator hoses hot.  Turn on heater, fan on low.  Grip both rubber heater hoses close to the firewall, from the engine compartment side.  They should be too hot to hold for long.  If they are not hot, then you have a lack of coolant circulation to the heater hoses.  If they are hot then access heater core, behind glove box area.  Blend door which moves as you chose HOT or Cold, should be cable controlled, move the controls and be sure the door is actually moving. Keep me posted
Dec 17, 2008 | 1994 Pontiac Firebird
Computers & Internet Logo
David Payne
David Payne
