Question about Neff 24 in. S5443X2 Built-in Dishwasher
My Neff 9000 081 894 (8506) Dishwasher doesnt move on from the pre-wash cycle, so it continues to wash at prewash endlessly if allowed. What is the problem?
  • 833 Answers
SOURCE: Neff dishwasher will not empty
Could be a kinked hose, diverter solenoid is jammed or burnt out. If the dishes are clean and the pump is working...then look at the above. If the spray isn't happening, the pump could be a problem. They are usually direct drive and you'll note that the motor isn't working.
Posted on Feb 10, 2008
SOURCE: NEFF S5456 DISHWASHER
We eventually, after several days of these problems, called a technician. It took him a couple of days to come round. Then when he did - he switched it on and absolutely no problem. His explanation was that if you interrupt the cycle whilst on a hot cycle, it sometimes thinks it's in flood mode. If you leave it off for a couple of days - it's OK.
Learning
1) Try not to interrupt hot cycle
2) If the pump continues to run - switch it off and wash dishes manually for 2 or 3 days.
Hope this helps others.
Posted on Feb 29, 2008
  • 1891 Answers
SOURCE: neff dishwasher water not been pumped out
ck drain for kink in hose . and if connected to disposal ck the hose at that point . must be clear. ck for bone/glass / toothpick/ ect / m m
Posted on Dec 17, 2009
  • 3247 Answers
SOURCE: our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Posted on Jun 05, 2010
caroldon
  • 17129 Answers
SOURCE: Neff dishwasher pump continues to
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. Also after the program is completing to the final stage the drain vavle/pump must work and cut off If this does not happen then the voltage at the inlet valve/drain pump must be checked or the fault relates to the controller. This means the controller is a suspect.
Posted on Jul 26, 2011
What is a pre wash? which detergent to be used in the pre wash compartment?
A prewash is exactly that a wash that takes plaxce before the main wash cycle for heavily soiled clothes, you can use the same detergent as you do for main wash. I do not think that I have ever used prewash.Hope this helps
Jan 06, 2016 | Kenmore Elite 45986 Front Load Washer
Why doesn't it work?
is the blue light a loading light ???(light that shines inside too allow you too see ) next all washers mfg after 2010 have a drain cycle after there first started , some of these can be mighty quiet almost imperceptible to hear , if you allow it to continue it will next add water and start to wash (if working properly) , the drain cycle was added because it was found out that everyone was prewashing dishes (silly I know) and then adding them to machine, this ,made for a lot of water runoff and then machine wasn't adding enough water for a total wash cycle , so mfg all figured it best to add a drain cycle first to all there washers
Sep 03, 2015 | Dishwashers
My Dishwasher (Westinghouse907 series) will not advance past the prewash/rinse cycle. I have cleaned out the filters. I also turned it off for a while and when I turned it back on it worked, but has now...
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 23, 2010 | Westinghouse 24 in. MDP531 RF...
Cycle won't finish Dishwasher goes on at 11.00 pm but is still in the cycle over 8 hours later
Hi
Thanks for using FixYa. If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | Neff Dishwashers
Our neff dishwasher has suddenly started to go wrong. When you switch it on a push a setting, it fills but does not wash. After about 10 mins it even drops the powder cube but still has not washed, it just...
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Aug 02, 2009 | Dishwashers
Whirlpool gold builtin dishwasher
Do not recommend premeasured tablets, usually too much soap. If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and make the soil sensor think the dishes are real dirty initiating additional wash cycles. Use rinse-aid for better drying performance
Apr 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
User Manual of Asea Cylinda 1200 Dishwasher
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Apr 25, 2008 | Dishwashers
Indesit Dishwasher DI67.Cycle phase lights(prewash and wash)flash
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
Feb 28, 2008 | Indesit 24 in. DI67 Free-standing...
Neff 24 in. S5443X2 Built-in Dishwasher Logo
76 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
