Question about Frigidaire ATF6700FS Front Load Washer
Can't find model no. Water isn't totally draining
    President:
  • 1,554 Answers
There's a problem in the drain system. Either the drain hose is clogged/kinked, the drain filter is blocked, or the pump itself is not working. The model number of the machine is not specified and troubleshooting may not be accurate but it may work. The following solution is for a front-loading washing machine.
Check to make sure that the drain hose is not kinked/clogged then remove the screws attaching the bottom flange of the kick panel to the machine cabinet then pull the panel down and off. Once the panel is off, the drain pump assembly can now be accessed. Detach the pump's inlet and outlet hoses then check the hoses for clogs and the pump impeller for damage and blockage. The filter is usually located in the big black hose that runs from the bottom of the tub to the pump. Remove this hose from the tub and clear the filter for any debris that may prevent water from draining out completely.
The may need to be replaced if everything is clear but water still doesn't drain out completely. Verify this condition by putting the machine to drain then keenly observe how the pump sounds while draining. Check the pump wire connections if it doesn't sound running. Indicate the exact and complete model number of the machine, if possible, for us to be able to diagnose the problem accurately should need further help.
Posted on Dec 29, 2010
Cant find drain button
There usually isn\'t a drain button, when the washer is done it drains the water, either you have a clog in the bottom, in the hose, or the drain pump is bad or blocked.
Read your manual to see how to check bottom screen and clean it.
If you need more help, make a new post with the make and model number, make sure you post the full and correct model number.
Apr 15, 2013 | Kenmore Dishwashers
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
My washer has gone through the cycle and the door will not unlock. Please help.
TYpically the door wont unlock due to not all the water draining from the tub so the water level switch isn't satisfied the water has drained and wont allow the door to unlock.
The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage.
GENE
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
Model ET18NKXDW06. Water dripping from freezer down back of refrigarator. Placed bowl underneath opening to catch water. Should be going down to catch pan right???? Help Nell
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Gene
Aug 10, 2011 | Whirlpool Refrigerators
Getting a "oe" error how
See
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Check the drain hose for blockage. and see if the water filters is clogged. Specific instructions will vary based on your specific LG model. Most LG frontloaders have an access panel on the front for the water filter.
Apr 21, 2011 | LG Washing Machines
We have an Amana dishwasher, model ADB1500AWW that will not drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 22, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
My LG model LD-12AS1 dishwasher will not drain, please help
Hi
Thanks
Rylee
Nov 08, 2009 | LG 24 in. LD-12BW5 Free-standing...
My Maytag dishwasher Model # MDB-3 will not drain. Please help. Thanks! Anna Giacobbe
Hi
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Have model du460-02. Start to wash but
Hi
Thanks
Rylee
Oct 27, 2009 | Dishwashers
Kenmore ultra wash dishwasher model 15752000 is not draining completely after cycle has finished
Hi
Thanks
Rylee
Oct 21, 2009 | Kenmore Dishwashers
Open Questions:
See all Frigidaire ATF6700FS Front Load Washer Questions
Frigidaire ATF6700FS Front Load Washer Logo
85 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
