Question about Samsung Washing Machines
My Front Loading Washer is 14 months old. It is not working properly. The door locks & fills with water. The soap is dispensed. You can hear the motor running but the drum doen Not turn. The alarm rings intermittently until the power is turned off. The wet clothes just sit in the washer.
  • beanem Jul 07, 2008
    The washer is a Samsung.
    Scholar:
  • 148 Answers
It sounds like a faulty door switch,when you close the lid,it pushes a switch in letting the washer know its safe to spin,replace the door switch ,it is a common problem as the switch is being pushed constanly open and closed,usally held by 2 screws
Posted on Jul 07, 2008
Soap dispenser is full of water and soap at the end of the cycle.
You will need to remove the top and clean the lines from the dispenser.
Nov 23, 2012 | LG WM-2277HW Front Load Washer
GE Harmony top load washer: The soap tray when filled with liquid soap will not properly dispense the soap when the water is filling the machine and the soap tray remains full of water and soap at the end...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 11, 2011 | Dishwashers
Water leaking during wash cycle
I've had this problem and immediately assumed it was the door gasket. However I actually sat & watched it for a whole cycle & discovered that water was running back out from the soap dispenser area and dripping from the bottom of the washer door. I removed the dispenser tray & discovered an inch of built-up soap had accumulated inside the washer, which was not allowing the water to drain through properly. Once I removed the soap & residue, problem solved.
Jul 30, 2010 | Washing Machines
I have a Frigidaire Gallaxy Series top loading washing machine, 4 years old that seems to be leaking from the bottom. Is this something I can fix myself? THANK YOU.
Before you buy a new $100 door gasket, pull out the soap dispenser tray and look inside the washer where it normally sits. If there is significant soap accumulation (even 3/8 inch), the water can become backed up and trickle down the washer front to the door bottom, making it look like a door leak. Fixed mine this way.
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Amana Front Load Washer Soap Dispenser
I suggest you use soap powder for 'front loading washing machines'. The cartons at the market have them specially marked.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lg tromm wm2277wh washing machine
Is the water valve screens plugged restricting the amount of water going into the washer other wise your pressure switch is reading the wrong water level.
Oct 13, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
151 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
