Question about Clarke Air Tools & Compressors
Clarke SE45C270 We have had to re-wire the star/delta starter control unit and need to know when the solenoid valve on the delivery pipe should switch. Presumably on start up it should vent when it is running in star and close when in delta??? Is the valve normally open or normally closed?
  • 37 Answers
SOURCE: sunroof-opens to vent on own, will not close
replace the switch.
Posted on Mar 21, 2009
  • 1388 Answers
SOURCE: starter valve dont close hatachi ec119sa (air compressor)
The start valve gives your motor a running start before the motor begins to load as the pressure increases from an empty tank. The motor strain is more profound when there is pressure in the tank. If you plug the valve, the motor will instantly encounter a heavy load because it has to force air into a partially filled tank. This extra load without the valve will shorten the life of the capacitors and motor windings. There could be two problems with your unit that can revealed by test. What actually closes the valve is a certain volume of air produced by the compressor. If the compressor is not pumping to full efficiency or there are leaks in the discharge hose the valve will not close. Or the valve is faulty. With an empty tank, plug the valve and run compressor and test airline for leaks with soapy water. If no leaks, empty tank of air and restart compressor and take note of the amount of time it takes to fill the tanks to shut off. If it takes an unusually long time to fill, then the compressor probably has valve problems causing low air volume. If the compressor fills to shut off in a short time frame as compared to a similar model then replace the valve. Leaking valves in the head will also cause the pump and discharge tube to run very hot. Parts are available at www.toolpartsdirect.com Good luck with your repair.
Posted on Apr 01, 2009
saabreur
  • 51 Answers
SOURCE: APC Solenoid Valve Knocking
The APC valve regulates boost pressure (via the wastegate) to avoid over-pressurising the engine. It ensures that a safe boost pressure isn't exceeded. Don't run with it disconnected or you risk blowing the engine!
Problem areas can include: knock sensor on the engine block (also poor quality fuel, dirty engine causing knock); engine ECU.
You need to provide more information about when this happens:
hard accelerating? (likely poor quality fuel, dirty plugs/engine causing knock) and general driving similar.
idling? possibly a knock sensor or ECU related problem
What rpm? what boost gauge pressure?
as an outside chance, maybe a sticky wastegate
Saabreur
Posted on May 30, 2009
SOURCE: VW Polo 2001 - Electric Windows wont open from Drivers side..
I removed all 3 switches from driver and passenger door, which is really easy with a flat head screw driver. took them completely apart, very carefully, with a small screwdriver out of a christmas cracker. put them back together again and 2 switches started working, so I put 1 in the drivers side and 1 in the passengers side so now my drivers door window opens and I lean over to open the passenger door. cool, no money spent...yet ;o)
Posted on Aug 07, 2009
  • 54 Answers
SOURCE: how do i connect he differenial pressure switch
Your question is a bit unclear, but I assume you are asking how to wire the pressure switch in a piston compressor.
See the diagram, below.
You should have a wire from the L1 (first incoming main voltage) terminal to the pressure switch, and from the other pressure switch terminal back to the starter coil. You will also have a wire from L2 (second main voltage terminal) to the overload, and from the other overload terminal to the other side of the coil. In this arrangement, the motor starter coil must be rated at the SAME VOLTAGE as your incoming power.
This diagram works the same for single phase machines (they just don't have the third wire coming from the supply through the starter and overload to the motor.
If your machine has other safety controls (like a low oil switch), It can be wired in series with either the pressure switch or the overload.
Posted on Nov 06, 2009
Motor starter
verify all three legs of the power are on. You could have a single blown fuse that would cause the motor to single phase and not run.
Apr 27, 2013 | Electrical Supplies
How to wire 3 phase compressor
depends if motor is wired in star or delta configeration as this determines strapping links in motor terminal box. check voltage for your country on motor data plate and this will tell you the configeration
Oct 21, 2012 | Clarke Air Tools & Compressors
Po410Secondary Air Injection System Malfunction
Common Problems That Trigger the P0410 Code
  • Defective Air Pump Check Valve(s)
  • Faulty Air Pump or Air Pump Relay
  • Faulty air control solenoids or vacuum lines
  • System may be restricted or plugged with carbon If you do not hear the Air Pump Motor start, then check the SAS Air Pump and relay. If you hear the motor, inspect the components that control the Air delivery such as the Check Valve Solenoid, the Check Valve and the rubber hoses, metal piping and passages. good-day !
Mar 19, 2012 | 2000 Chevrolet Lumina
Who to wirie star delta starter
This site gives an excellent explanation of the star connection and the delta connection.
Answers.com - How do you wire a star delta motor
Then this site shows the wiring of the motor windings and the star delta starter and what occurs when the starter switches from star to delta.
Moeller - Star-delta switching of three-phase motors - Automatic star-delta starters SDAINL
Good luck.
Dec 20, 2010 | Air Tools & Compressors
I WANT TO KNOW WHERE IS THE STARTER LOCATED SO I CAN REPLACE IT..
REMOVAL & INSTALLATION 2.0L SOHC Engine With Automatic Transaxle; 2.4L Engine
  1. Disconnect the negative battery cable from the left strut tower. The ground cable is equipped with a insulator grommet which should be placed on the stud to prevent the negative battery cable from accidentally grounding.
  2. Remove the air cleaner resonator.
  3. Remove the 3 bolts attaching the Transmission Control Module (TCM). Do not disconnect the TCM wiring. Move the TCM to gain access to the upper starter mounting bolt.
  4. Remove the upper starter mounting bolt.
  5. Raise and safely support the vehicle.
  6. Remove the positive battery cable nut and disconnect the cable from the starter.
  7. Disconnect the push-on solenoid connector.
  8. Remove the lower mounting bolt that attaches the starter to the transaxle.
  9. Remove the starter from the vehicle. Fig. 3: Starter motor wiring terminal connections — 2.0L SOHC engine with A/T; 2.4L engine 90902g12.gif
    To install:
  10. Install the starter onto the transaxle and the lower mounting bolt.
  11. Tighten the mounting bolts to 40 ft. lbs. (54 Nm). NOTE: Before reconnecting the wiring to the starter solenoid, be sure to clean the wiring of any dirt or corrosion.
  12. Reconnect the positive battery cable to the solenoid post and tighten the retaining nut to 90 inch lbs. (10 Nm).
  13. Reconnect the push-on solenoid connector.
  14. Lower the vehicle.
  15. Reinstall the upper attaching bolt and torque to 40 ft. lbs. (54 Nm).
  16. Reinstall the TCM to its original location and install the mounting screws.
  17. Reinstall the air cleaner resonator.
  18. Reconnect the negative battery cable.
2.5L (VIN N) Engine
  1. Disconnect the negative battery cable.
  2. Most vehicles will require the removal of the front exhaust pipe. Use penetrating oil on the fasteners to ease removal.
  3. Disconnect the starter motor electrical connections.
  4. Remove the starter motor mounting bolts and remove the starter. Fig. 4: Exploded view of the starter motor mounting — 2.5L engine 90902g10.gif
    To install:
  5. Clean both surfaces of the starter motor flange and the rear plate. This is important since the starter grounds through its case and the transaxle flange to which it attached. Some remanufactured starters may have paint on these areas which should be cleaned off before installation. Install the starter motor onto the transaxle and secure with the retaining bolts. Tighten the bolts to 20–25 ft. lbs. (26–33 Nm).
  6. Connect the electrical harness connectors to the starter.
  7. Connect the negative battery cable and check the starter for proper operation.
2.5L (VIN H) Engine
  1. Disconnect the negative battery cable from the left strut tower. The ground cable is equipped with an insulator grommet which should be placed on the stud to prevent the negative battery cable from accidentally grounding.
  2. Raise and safely support the vehicle.
  3. Loosen, but do not remove, the exhaust pipe-to-manifold retaining nuts.
  4. Place a drain pan under the oil filter to prevent oil spillage, then remove the oil filter. For additional details, refer to Section 1. Fig. 5: Loosen the exhaust pipe-to-manifold retaining nuts to provide removal clearance for the starter 90902p01.jpg
    Fig. 6: Location of the positive battery cable nut (1) and the push-on solenoid connector (2) 90902p02.jpg
    Fig. 7: After removing the oil filter for access, unfasten the retaining nut and disconnect the positive battery cable 90902p03.jpg
    Fig. 8: Disengage the push-on starter solenoid connector 90902p04.jpg
  5. Remove the positive battery cable retaining nut and battery cable from the starter.
  6. Disconnect the push-on solenoid connector.
  7. Remove the 3 bolts that attach the starter unit to the transaxle.
  8. Pull the exhaust pipe down just enough to provide clearance for the starter motor. The exhaust pipe does not have to be separated from the pipe-to-manifold threaded studs.
  9. Remove the starter unit from the vehicle. Fig. 9: Remove the 3 starter motor-to-transaxle housing attaching bolts 90902p05.jpg
    Fig. 10: Pull the exhaust pipe down just enough to provide removal clearance for the starter 90902p06.jpg
    Fig. 11: Carefully remove the starter motor from the vehicle 90902p07.jpg
    To install:
  10. Install the starter unit onto the transaxle and install the 3 mounting bolts.
  11. Tighten the mounting bolts to 40 ft. lbs. (54 Nm). NOTE: Before reconnecting any wiring to the starter solenoid, clean the wire terminals of any dirt or corrosion.
  12. Reconnect the positive battery terminal and retaining nut to the starter solenoid post. Tighten the retaining nut to 90 inch lbs. (10 Nm).
  14. Reinstall the oil filter.
  15. Lower the vehicle.
  16. Reconnect the negative battery cable.
Aug 19, 2010 | 1997 Chrysler Sebring
When doing a load and selecting Cold/Cold temps, I am only getting HOT water. All the temp settings are only allowing HOT water to flow. I have a Whirlpool GHW9150PW0 model. Anyone know why this is?
The cold part of the water inlet/mixing valve assembly (part #8181694) is not working. Disconnect power to the machine then remove the three screws at the back of the top panel securing it to the cabinet. Once the screws are removed, slide the top panel to the back of the machine then lift it off.
Check the valve solenoids using an ohmmeter. Disconnect a wire from each of the solenoids then measure the resistance between the terminals of each solenoid with the ohmmeter set to X100. The resistance of the solenoids must be almost identical at about 800 ohms.
Check the continuity of the solenoid wiring harness to the central control unit. Make sure the connector at the central control unit is properly seated to ensure good connection. The 4-wire valve solenoid connector is the fourth connector from the left (facing the front of the washer) of the central control unit.
Disconnect the solenoid wires from its terminals if the resistances of the solenoids found above are the same and there's a good connection between the solenoids and the central control unit. Cleaning the terminals will help. Reconnect the solenoid wires in place of the other solenoid wires, and then start a new cycle to check if the temperature of the water coming into the washer changes.
Replace the water inlet/mixing valve if one of the following is observed:
  1. The resistances of the valve solenoids are not the same; one solenoid is open, and the connection between the solenoids and the central control unit is okay.
  2. The water temperature does not change after the hot and cold solenoid wires are interchanged.
Remove the fill hoses then remove the valve assembly mounting screws. Disconnect the valve assembly outlet hose then remove the valve assembly from the cabinet. Connect the outlet hose to the new valve assembly then mount it into position in the cabinet with the mounting screws.
Slide the top panel into position then secure it the three screws to the back of the machine.
Please let us know how this guide helped you or not so that we may know how it worked and how to improve it, if necessary.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
2004 Yam VStar 1100 motorcycle-starter spins but will not engage
The starter one-way clutch in the left gearcase is bad.
Mar 07, 2010 | 2004 Yamaha V Star Custom
Need star delta control wiring daigram
49fb442.jpg STAR/DELTA MOTOR WIRING.
This is the wiring you need to follow.
Feb 11, 2010 | Siemens Seimens Arc Fault Breaker
I want to use one condener unit to cool a freezer and a cooler at two different temperatures, how do I do that? with a head master?
You need to split the delivery and return tubing, then install a solenoid in each delivery tube. The solenoid valve will be controlled or powered by a thermostat in each compartment. You then install a low pressure switch on the suction or return side near the compressor. This will switch the compressor off when both solenoid valves are closed. Hope this makes sense.
Nov 05, 2009 | Freezers
Air Tools & Compressors Logo
211 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
