Question about Blanco Home
My Blanco Rohtiel Sublime 500 sink has developed a crack and is now leaking. Can it be repaired? The company from whom we purchased it is out of business and it's been over 2 years since it was installed. Can you help?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Not really, when porcelain starts to crack,and leak. it is very hard to repair, you can make a temp repair, but it wont last long...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
I purchased a Blanco waste strainer #441099. It is brown plastic for a granite kitchen sink. My plumber could not use it. said it didn't have a ring that holds the disposal flange. There is a groove...
This strainer is not for a garbage disposal. The strainer for the garbage disposal comes with the disposal. If you bought two of these for the sink, then that's why you have one left. The disposal has its own.
Jul 23, 2011 | Blanco Sink Waste Strainer / Stopper...
How do we repair leaking faucets and clogged drain
Hi. To fix leak, replace cartridge in valve. To clean out drain, Clean out trap under sink.
Jun 09, 2011 | Blanco Classic Single Handle Faucet with...
I'm in the North York - Toronto area, I have a blanco double compartment sink, black, it's approximately 15 years old and it has several chips in the enamel or porecelain. Is there someone who can repair...
If this is a SILGRANIT sink you will need to contact Blanco to find this out they do not reveal the material used in this sink and they may be able to help. This is the web site for Canada.
http://www.blancocanada.com/
Mar 14, 2011 | Blanco Home
My sink has a crack. can this be filled & sanded
Yes. Porcelain sinks can be fixed. Your local home improvement store will have it. It comes as a kit. easy to use and takes about 24 hours to cure.
Dec 25, 2010 | Blanco Axia Silgranit Anthracite 6S Drop...
Leak from blanco aderlphi tap above sink line may be a washer required
this could be a leaking cartridge or more likely a likely a leaking o-ring that sits around the base and seals the joint between the spout and the base
Jul 01, 2010 | Blanco Plumbing
I need a repair kit for a cracked silgranit sink
Hello., Yes definitely. Go to any home depot or hardware store and have one of the clerks show you the assortment of adhesives that will work on your problem. The fast drying clear resins and the one minute clear epoxy both work great.
Feb 03, 2010 | Blanco Axia Silgranit Anthracite 6S Drop...
Deep scratches on blanco granite sink
The only way to fix scratshes and chips from a granite surface is to use a sander. You would be safer to have the company thet installed it, resurface it. They have the proper equipment.
Feb 17, 2009 | Blanco 511-620 supreme 2 One-Piece...
How To Connect Sinks Drain
No matter what type of sink you purchase, the drain and water-supply connections are generally installed in the same way. Hand-tighten a female adapter onto the drain stub-out at the wall. Slide slip nuts onto the drain arm and the sink's tailpiece. Fit a P-trap in place and tighten the slip nuts by hand. Connect flexible water-supply tubes onto the faucet's tailpieces, and route them to the shut-off valves. Tighten coupling nuts with an adjustable wrench. Remove the faucet aerator, turn on the water, check for leaks at the shutoff valves, and then turn on the faucet to check for leaks in the drain assembly. Replace the aerator.
Aug 27, 2008 | Blanco 510-879 Single Bowl Undermount...
Home Logo
191 people viewed this question
Top Blanco Home Experts
J.D. Browning
J.D. Browning
uggachucka
Level 1 Expert
Tom Chichester
Are you a Blanco Home Expert? Answer questions, earn points and help others
