Question about LG Flatron L1750S 17" LCD Monitor
The screen on my monitor is all white, and when I do the pressure with my thumb top of the screen returns to normal.
  • 11,361 Answers
Look for loose connector between the LCD panel and the logic board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 29, 2010
Diplay screen
This could be a connector problem in ur screen, to check whether it is problem, try tp press slightly then harder by your thumb on top screen,if it went white and return back to work and son , then it is a connector and you have to replace it, I think it's not expensive, just cheap ones. Good luck
May 16, 2012 | Nokia mobile C2-00 Dual SIMbiosis
Screen is white
is LCD monitor internal cable defective, go to the repair center.
Dec 25, 2009 | Acer Extensa 4220-2148 Notebook
My TFT LCD Monitor, serial #MT-NI-DYLM2286 produces a light pink backround, but prints clear. Is there some way to return the monitor to a clear white backround?
rjmusvi, Sometimes the VGA connector at the rear of the PC needs to have it RESEATED 4-8 times to see if it returns the screen to NORMAL colors being displayed on the LCD panel!!! Do this with the POWER OFF to both PC and LCD monitor!!! Also check to see if any of the pins in the monitor to pc plug are bent or pushed down into the connector body. 12fixlouie on fixya
Dec 03, 2009 | Soyo Computers & Internet
Hi, I just purchased a 22inch 2233BW samsung monitor, the label on top "Syncmaster 2233" and right side "50000:1" is a little faded out, is this normal or it means it was used and repackaged? also the top...
I would return it for a New Model.
Ask to see a display model.
The unit should also have a build date on the tag as well.
Its your money. spend it your way. !
Sep 30, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen fades to white, everything freezes, then returns to normal
My first thought is a video inverter.
Install an external monitor and see if the problem persists.
If it doesn't then it is the LCD on the laptop.
Good luck
God Bless
-Carlos:
Jun 19, 2009 | Compaq Computers & Internet
Toshiba Satellite A105 Screen Problem
Only thing i can say is this. Try to get a new screen because from what you are describing. I believe that the monitor is damaged inside. If you got the laptop recently i will suggest that you get it returned for a different one.
Mar 08, 2008 | Toshiba Satellite A105-S4004 Notebook
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Something wrong with my lcd screen
As a quick test I would try connecting the monitor to another PC to make sure the problem follows the monitor. If it does then the likely cause is a circuit board or possibly a poor connection inside the monitor. Since working on this would require opening the monitor case and voiding your 1 year warranty I would recommend you contact Samsung support for a warranty replacement as soon as possible. When you do make sure you mention the problem goes with the monitor and any other troubleshooting steps you have taken. Also the replacement they send will itself be something that was returned and fixed.The only warranty you will get will be whatever is left of your original year so definitely get this taken care of as soon as possible.
Jul 11, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
175 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
