Bought a silvercrest electric wrap around blanket for Christmas. No instructions. It has stopped working. It says on the box that there is a three hour safety cutout. How do you reset it (if that is what the problem is)? I've swithed it off and on andleft it a day and there doesnt seem to be any life in it. Please help.
  • 133 Answers
SOURCE: I bought a Sunbeam electric
The only thing you can do, other than pull all the wire out to test it, is check the temperature control. If you have another you know works or can borrow one to test the blanket, that's the easiest. Else, you will need to use a "Glow Stick". A Glow Stick is an electrical tester that does not require physical contact with a bear conductor to detect voltage. They are available at Hard Ware stores, Menard's, Home Depot, etc. Plug the blanket controller into the wall outlet and touch the 2 wires near the thermostat. If it glows, the cord is good and the outlet has power. Now test the wires coming out of the thermostat that go to the blanket. Turn the thermostat way up and down and see if the light glows. If no, the thermostat is bad. If it glows, indicating power has made it through the thermostat, continue to test along those wires to the blanket. If you have power at the plug on the blanket, continue onto the blanket along the wires that provide the heat. The light will continue to glow on-till you get to the break in the line. When the light goes out, that's the break point. If you do find a break in the blanket and would like me to walk through the repair, I will be happy to. The Glow Stick is a good investment for safely testing anything electrical without the risk of being shocked. Please rate this for me. I am new to the site and need to improve on writing what I am thinking. Let me know how it goes for you, OK?
Roger
Posted on Apr 02, 2011
SOURCE: lost the instructions on how to play cranium
The instructions say to remove your shoes, spread the 16 pads around, about two kid feet apart (separate colors/shapes as best you can). Put the hullabaloo game nearby and turn it on, button near batteries. It gives the instructions as you go.
Posted on Feb 08, 2009
ginko
  • 19396 Answers
SOURCE: Replacement Cartridges and Reset Button Orange Led
That usually means that the chip on a re-manufactured cartridges had not been reset properly.
Ensure you removed the little cello strip from bottom side of cartridge.
Try unplugging printer power cord for five minutes, and also re-fitting cartridges.
If that does not work call the company and have them replaced.
Note: for the future, it is better buying always original new cartridge rather than refilled/refurbished ones, as you do not know as many times a refilled had been used. On sporadic occasions refilled cartridges can fail and damage the printer.
Posted on Apr 11, 2009
SOURCE: Sunbeam Queen Size Electric Blanket Flashing F2
it means there is some sort of problem somewhere with your blanket .
Posted on Nov 15, 2009
SOURCE: I bought the Thomas Zip
http://service.mattel.com/instruction_sheets/R9634-0920.pdf
Posted on Mar 06, 2011
My daughter bought me an electric blanket for christmas last year. I plugged it in last night, all lights are on but no heat. What can be done
Replace it. It is likely the heating element failed while it was dormant. Electric blankets are well known for doing this.
Dec 05, 2016 | Home
Someone gave me this blanket (used), but it worked fine at their home , tried it at my home , it will not work at all . Any suggestions ?
Try another wall plug. Otherwise, you have a defective electric blanket. Unless it works perfectly, I would clip off the contols and use it as a blanket. You don't want to be the next hotdog wrapped in a shorted electric blanket.
Feb 14, 2016 | Home
I need the instructions for twister dance...
Try this link. We got this game for our daughter and must of thrown the instructions away with the Christmas wrappings! Happy Dancing!
http://www.hasbro.com/customer-service/browse/_/Ntt-dance%20twister?Ntk=All&Ntx=mode+matchallpartial
Dec 25, 2012 | Hasbro Twister Dance Game
Sheets and bedding get balled up in dryer and don't get dry.
I have Design a new solution it is the Dwadder.
Dwadder made from HDPE plastic. The Dwadder is the first ever Dryer Device that does dry your sheets and blankets faster! The Dwadder keeps your sheets and blankets from wadding up in the dryer. This will save you Time and Money when drying. Dwadder can cut your drying time up to 30 mins or more. Two sheets or blankets can be strapped to the Dwadder at a time to keep from wadding up in the dryer.
One of the most time-consuming uses of a dryer is drying blankets and sheets. The reason it takes so long is the blanket or sheet can be twisted into a tight wad or ball during the drying cycle. Once this happens the dryer is incapable of drying the center of the wadded blanket or sheet. The solution today is to take the blanket or sheet out of the dryer halfway through the drying cycle and unwad the bundle of sheets or blankets. Then place the blanket or sheet back into the dryer to restart the dryer cycle over and over again until the blanket or sheet is dried. If you forget to unwad the blanket or sheet when you get ready to make the bed, the blanket and or the sheet will be wet.In order to fix this problem, the Dwadder is strapped to the sheet or blanket using a silicone cord before it is placed in the dryer. Once the dryer is started the blanket or sheet will wrap around the Dwadder allowing a space to be in the center of the blanket or sheet. With the space that is created by the Dwadder the center of your blanket and sheet will dry faster and will not roll into a tight ball or cylinder shape. This will help save time drying your sheets and blankets. The device will also prevent wadding of your sheets and blankets so you don't have to unwad your blankets and sheets half way between the drying cycles.
How to Use the Dwadder
Simply pull half of your blanket or sheet out of the washer. Then pull the silicone cord to slide the blanket or sheet between the silicone cord and the Dwadder. Slide the Dwadder to the center of the sheet or blanket then put your blanket or sheet in the dryer with the Dwadder attach to your blanket or sheet. You can use both silicone cords for two small blankets or sheets just don't place 2 blankets or sheet on top of each other or it will take longer to dry. For Video instructions please go to the website at www.Defuturesolutions.com or Youtube.
DESIGNING FUTURE SOLUTIONS defuturesolutions com
Feb 02, 2018 | Samsung DV448AEE Electric Dryer
Anyway to keep it warm at night so it doesnt stuggle to start in the morning
Big heavy blanket or a bottle of isoheet or isopropyl alcohol or a bottle of stabil will keep the gas and lines free of water and cold and condensation. or wrap with heavy blankets.
Dec 08, 2009 | Lincoln Electric Ranger 305G K1726-4...
Oct 08, 2009 | Kitchen Appliances - Others
INSULLATION BLANKET
Get his **** back out there.
Apr 16, 2009 | Dishwashers
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Heating & Cooling Logo
437 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
