I just bought the correct printer cartridges for my Cannon printer and its says that I need to align it. How do I do that so that my printer with print again? Thanks! Becky
  • 691 Answers
If you let us know what printer you have we may be able to help you. In the meantime how about you look at the manufacturers web page for a users manual.
Posted on Jul 07, 2008
Loading ink cartridges
what are the numbers mentioned over the cartridges.
Jul 03, 2008 | Canon PIXMA iP1600 Printer
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
I have a streak running vertically down the page where there is no print.
I think I can help, try these things.
take out your printer cartridges
wipe the printer spouts with a damp cloth or paper towel.
replace the ink cartridges.
The printer should prompt your to do a printer alignment test.
follow the steps for alignment your cartridges may just need to be calibrated.
If it does not prompt you there should be some instruction in your owners manual on how to start a new printer cartridge alignment calibration process.
This should work otherwise here's Cannon's info:
Heres a link also for Cannon support
also heres a link for on screen printer manual support
look below on page for download
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15651#DownloadDetailAct
please remember to rate my help and leave a testimonial if my help was appreciated.
Mar 26, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a cannon printer bjc 2100. It is printing
After replacing ink cartridges, you generally have to perform an alignment routine. On some printers, they have an automatic alignment function, others require the printing out of one or two sheets of paper and a possible adjustment via the service section of your printer software. If this isn't done, you can have an output similar to that you describe.
Oct 24, 2009 | Office Equipment & Supplies
After putting in new ink cartridges how do I align them?
click start start botton go to settings click printer and faxes and right click to your printer cannon mx310 go to properties click maintenance
May 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannon IP5300 line missing in print
you should open the software or on the printer select clean print cartridges, or align cartridged
Mar 17, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon Incompatible Ink Cartridge Issue
I refilled my ink cartridge and you have to reset the chip on the cartridge,go back where you refilled your ink and ask them to reset the chip.Thats if you refilled the ink or you baught a canon one return it to the store.
Dan
Sep 10, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Open Questions:
k24674
