Question about Magellan MAESTRO 3100 98083401 GPS Device
My gps wont power on I looked at the batttey and it looks swollen a month before this I had tobuy a universal charger im wondering if this could be the problem.
    President:
  • 1,111 Answers
Hi jenniferj936,
your model gps doesnt need a battery to operate. if you know how to open the gps, open it and disconnect the battery, then plug in the home or car charger, then press and hold the power button for up to ten seconds. if it starts, let me know and ill give you a link to buy a replacement battery. if it doesnt start, please continue reading.
this is a very common problem with your model gps
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Feb 10, 2011
My tomtoms green ligt is on but will not power on
there is a swollen capacitor in the power supply section that needs replacing.Just look for signs of swollen capacitors and change them. this is the reason that it wont start up.
G.
Jun 08, 2011 | Tomtom ONE GPS Receiver
Why wont my USB charger will not stay in back of gps?
There should be enough friction from the plug and the cable to hold it in, look and see if the power receptical has fallen into the GPS or possibly some of the pins have fallen from the cord. But it sounds as if the receptical has broken.
Hope this helps!
May 10, 2011 | Garmin GPS
The power on button is not working. Magellan only comes on when plugged in to power.
hi wptbtot,
its uncommon for those power switches to fail but it does happen. are you looking for another switch or someone to replace it for you?
follow the link below for the magellan power port and ask that fellow (me) that sells them for what ever help your looking for. im not allow to help you directly from the fixya website unless its technical info.
if you just need instructions on how to fix it, i can still help you here on this website.
Bill
Feb 10, 2011 | Magellan GPS
Charger wont work. little red light on the
You need the correct cable for you car the one that you connect to the PC, they both look the same the PC lead wont work in the car you need the one that just charges in the car this normally has a 12V lighter socked at the feed end.
This and one other is the only SATNAV that has this two lead requirement as far a I know that is.
Jan 27, 2010 | Garmin nuvi 255W GPS Receiver
My magellan roadmate 1200 will not turn on
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
if you tried charging it with both house charger and car charger and tried to start it like i explain and it still will not start, its most likely a bad power port which is very common with this model and many other magellan models.
Sep 10, 2009 | Magellan RoadMate 1200 GPS Receiver
Panasonic LA95 Portable DVD
any flashing red powerlight ?? (assuming theres any charge left)
if the powerlight flashes quickly then the units kaput ( bin it)
slow flashing means the microswitch may be stuck (the one that turns off the screen when you close the lid.
you may have to be sneaky at a dealer and ask to plug in to a new mains unit ( most new panasonics still use the same power supply voltage and ampage. if it works then run away quickly and go buy a universal power supply, if it doesnt , well your in the right place tobuy a new one ??
Mar 11, 2009 | Panasonic DVD-LA95 Portable DVD Player
Nuvi 760 will not turn on !!
I just had the same issue, after using the unit for 11 months.
WOULD NOT power on... and i freaked.
This is what solved it, no matter how strange it sounds...
I held the 'power switch' to ON for 20 secs, then it came on again.
I hope this works for you as well!
-Drew
Feb 18, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
"Dead" Magellan RoadMate 2000T
do you still need help with this gps. im sure i can help you as i fix these everyday.
Bill
Aug 09, 2008 | Magellan RoadMate 2200T GPS Receiver
Power pin fell off inside of Magellan Roadmate 3000T
I managed to solder my connector back in place. The ground trace broke away from the board so I had to install a jumper to ground. I put RTV on the connector to secure it after the repair.
Worked great for a few weeks until it was dropped again and lost power, something else has a broken connection.
Jan 05, 2008 | Magellan RoadMate 3000T GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
103 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
