Question about Electrolux Epic 6500 Vacuum
I cant get service of compressor GL 90 TG in rajkot and want to know about deler and service centre in rajkot
I can't get my Hoover floor cleaner to turn on. What should I do?
If you have checked that the outlet you plugged it into has power and it still doesn't work, you take it to a Hoover repair centre, or you buy a Dyson :>)
Let me know as a COMMENT if you want me to find your nearest service centre. Tell me city and state, or town and county depending on where you live.
Mar 20, 2016 | Hoover Vacuums
I need to know the correct position of the rear wheel assembly and spring to istall in a electrolux renaissance power nozzle model#n106a in the base.Is this power nozzle refered to as PN5,6 or7? I also...
any Aerus deler will have the plate go to aerusonline.com they have dealer listing in your area. Beware they will try to sell you a new one. Part should be around $10 you may want them to put that axle and spring and cover on it is hard to do. A hint though for a DYI the spring barb goes in a little square hole in the weel channel. Good luck .
Apr 03, 2014 | Electrolux Guardian Bagged Canister Vacuum
Contact service centre in Perth WA
Hi There,
Alec from VacuumSpot here. If you give Electrolux head office a call on 1300366366 they will let you know the number of an agent near to you.
Oct 29, 2012 | Electrolux Trilobite Vacuum
Hi I have just purchased a Sieger Vapor Steam Mop do I need to put the clip on when steam cleaning tiles & lino or just for when I do carpets Cheers Lelly
you only use it for carpets. by the way, did you know you cant get the mop pads !!!!
Q to target customer service:
Dave: can i get some spare mop pads in store?
Cust service: no we dont sell them
Dave: ok where can i get some more?
Cust service: you cant, its a target mop
Cust service: its ok, you just wash them and reuse
Dave: yeah i wash my jocks, but i dont wear them forever, they wear out and i dont rub my bum on the floor
Cust service: you can't return it.
Dave: (NOT 100% happy, would you be?)
Feb 04, 2011 | Vacuums
Geepas service centre ernakulam
my geepas tourch is not working, have your show room in malabar side
Jul 22, 2010 | Vacuums
Replace control switch on Dyson 04 Model
You have to remove the yellow on /off switch first. This is actualy a cover to the switch below. I removed mine with x1 of the centre prongs of a fork. Bend the centre prong to 90 degress to the fork handle, and put a tiny kink at the end of that prong. (you should end up with a funny lookink "Z" shape. Bend the remaining x3 prongs totally out of the way. Keeping the yellow switch cover up - use pliers here- push the singular prong down the flat egde of the cover. ie inboard. When you think you have the clip pushed in pull the cover up with the pliers and - hey presto access to the actual sw and wires is revealed.
Oct 02, 2009 | Vacuums
How can I service my kerby vacuum myself
remove the case screws from the cover and take off outer shell, then take to someone with an air compressor and gently blow out any dirt, then with a can of light weight weight oil lube any places that rotate, check your belt and wires for connections and replace outer cover and you should be set
Oct 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Is barely sucking up anything
I dont fix vacumes but I would say if you took the vacume apart you will find that it has a blockage. Clean it out and it should work fine.
Jul 11, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
164 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
