Question about Philips Magnavox 20MT133S 20" TV
I am trying to turn off the closed captions on my tv. I hit the cc button on my tv remote however nothing changes.
  • 4,234 Answers
If you are receiving the TV signal from a cable box, it is possible that the box is generating the CC not the TV. Verify that the cablebox has CC turned off as well. If that is not the case, please update this and I'll check the service manual for additional possibilities.
Dan
Posted on Dec 29, 2010
  • indyjones812 Jan 04, 2011
    I had the same problem, and found out it was subtitles, and not cc. If you have direct tv. simply hit the yellow button to see if it the subtitles setting is on. mine was.
How do i turn off the closed caption on my toshiba 51h84 tv? i tried setting via the remote and changed the CC option to OFF but i still see the closed caption wording...it is driving me crazy!! help!
What is the source of your TV signal: Cable? Dish Networks? DirectTV? Antenna?
Many times the Cable/Dish Networks/DirectTV controller also has an option for closed captioning. Please verify that a controller is not setup to deliver the CC data.
Also, try setting the TV CC using 'C1' or 'T1' and selecting 'Enter' to accept the change; then come back and set CC to 'Off' again to see if toggling on/off helps.
Dec 31, 2014 | Toshiba 51H84 51" Rear Projection...
We accidentally hit some button on the control that made a big black square come over all our channels. We have tried everything and cannot get this off. We realize it is locked and have tried changing...
Hello
Closed Caption function is set to On in your JVC. look if there any button marked as "CC" on its remote control. If it is there, hit it till the closed caption function go off from your tv screen. If there is no such button found, get into its menu option, surf through, and get in to the closed caption option, set the close caption function OFF in that window. OK.
Apr 11, 2011 | JVC AV-32D502 32" TV
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
Black box appears on every channel
Hi:
This black box is the close caption box, you must of turned the feature on. Go into you menu setup screen and under CC option turn off Close Captoin, or you may have a CC button on your remote that you hit by mistake, try hitting this button until it says Close Caption off.
Dec 24, 2009 | JVC AV-32D305 32" TV
I do not know how to turn off the closed captioning on my son's orion tv set. I do not know the model type. I do know that closed captioning options are not on the menu.
If you have the original remote look for a button labeled "CC" or "Caption/Text" press this button till the screen says caption off.
Jul 06, 2009 | Televison & Video
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Remote really?
SOUNDS LIKE U HAVE CLOSED-CAPTION TURNED ON. HIT MENU, GO TO RIGHT TO C.C.( CLOSED CAPTION) AND SELECT OFF, HIT EXIT BUTTON. GOOD LUCK
Oct 13, 2008 | Toshiba 36AF42 36" TV
Closed captioning issues
Hit The PIP Button On The Remote Until It Says CC OFF
Feb 15, 2008 | Philips 25PS40S 25" TV
Jvc flat screen television model AV32F713 Black box on screen.
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
Nov 29, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Philips Magnavox 20MT133S 20" TV Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
