Question about HP PSC 2175 All-In-One InkJet Printer
I need to replace hp psc cartridge but I can't find where it is located, let alone how to replace it.
5 Suggested Answers
bandana_gyrl
  • 181 Answers
SOURCE: HP PSC 1500 Needs both cartridges to work?
Yes - both cartridges need to be inserted to print.
Posted on Jan 17, 2009
SOURCE: Cannot locate ink catridge for HP PSC 750 printer
With power on, simply lift up from the hatch located on the front of the unit. The ink jet will slide to the middle position.
Posted on Mar 28, 2009
SOURCE: how to install the print cartridge on the hp psc 2175
Changed black ink cartridge screen reads press enter to align cartriges, and it won't align.
Posted on Apr 03, 2009
edmacias
  • 70 Answers
SOURCE: how to change ink cartridge on hp psc 1510
Hi, Please check this link: http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
Refer to pages 43-48 (printed number on the page or pages 46-51 in the PDF page guide)
Hope this works for you.
Cheers, Ed
Posted on Nov 25, 2009
How do i change scanner light bulb on hp psc 1205 printer
Most of the time the light bar is not the problem when it comes to print quality issues. Those are typically ink cartridge or printhead issues. Try printing a self test page and compare.
Dec 19, 2014 | HP PSC 1205 InkJet Printer
Can't get HP PSC 2530 to accept re-filled catridges! Both are full but it keeps telling me to remove and check right-hand one; can't by-pass or override the message.
Hi
In order not to have error messages in your printer
You need to remove all the air bubbles from the cartridges
the best way when you do it alone is bu using refill clips
check here the right method
Hi pls vote us to keep us alive
Nov 08, 2010 | HP PSC 2350 All-In-One InkJet Printer
Display says "Remove and check right cartridge", but even replacing the right cartridge with a new one does not fix the problem, and the printer will not function.
This HP PSC 1610 all in one - scan / fax / copier *** printer, normally the cartridges inserting
locations might have caused some issue. When you install the genuine catridge and getting the
error. Might be the catridge inserter might be replaced with local hardware engineer is the best solution. Moreover this type of printers are HP itlsef is giving the maximum life of 3 years only as printer life time.
In our office we are using HP PSC 1110 - 4-in-1 printer and it is having the same problem, but when the message displayed, we will just say OK and it will automatically print the necessary pages.
Best of Luck always.
Jul 16, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP 6110 check cartridge error won't clear with new cartridges. Anyone know how to fix this?
You could try this way first as its a lot quicker and easier than the official steps from HP:
Just hold down the ENTER button and then press the MENU button. There will be a series of 3 fast, high beeps. Then everything resists and is a-okay. Both problems go away.
OR The HP way as listed below:
The ink cartridge-related error messages may occur due to one
of the following reasons:
* The ink cartridge does not make a proper electrical contact
* The cartridge is bad or wrong
* The cartridge is remanufactured or refilled
To resolve the error, follow these steps:
Step one: Check the print cartridges and clean the cartridge contacts
Even if the cartridge is new, follow these steps to clean the print
cartridge contacts. Print cartridges have a substance on the contacts
to keep them from corroding during storage that may cause poor
electrical contact between the print carriage and the print cartridge.
1. Verify that the product is turned on.
NOTE: If the HP product is not turned on, you will not be able to
remove the print cartridges.
2. Open the top cover or the cartridge access door in one of the
following ways:
* Pull the control panel forward and then lift the top section
toward the back.
* Open the access door on the left or right of the unit. This door
may be located under the scanner glass lid on some flatbed
products.
* On many flatbed products, you raise the front center section of
the unit to access the print cartridges.
* Raise the cartridge access door on the front of the product.
3. After the print carriage stops moving, unplug the power cord. You
must unplug the power cord to prevent the print carriage from
moving.
4. Remove both print cartridges.
5. Verify that the part number on the cartridge is the correct part
number for the all-in-one and that the carriage is not blocked
preventing the cartridges from moving. Visit the following HP Web
site for a cartridge compatibility chart.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpa00586
6. The electrical contacts of the print cartridge are coated with a
thin layer of grease to protect them from oxidation. This grease
may inhibit the electrical connection and should be removed. Using
a cotton swab or cloth lightly moistened with distilled, filtered,
or bottled water, clean the electrical contacts of the cartridge.
This usually occurs with a new ink cartridge, but may also occur
with an older cartridge.
NOTE: When an all-in-one is used frequently for black and white
printing but infrequently for color printing (for example,
an all-in-one that is used primarily as a fax machine), the
color cartridge will still eventually fail and need to be
replaced. The pins in the print carriage can cause dents
on the contact points of the color cartridge over time
(usually between six and twelve months).
7. Wipe the contacts with a dry, cotton cloth.
8. Reinsert the cartridges and lock them in place.
9. Close the top cover or access door and plug in the power cord.
10. If the error persists, repeat these steps. If further cleaning
fails to resolve the error, proceed to "Step two: Clean the
print carriage contacts" section.
Step two: Clean the print carriage contacts
Have the following materials available to clean the print carriage
contacts:
* Cotton swabs or any soft material that will not come apart or leave
fibers (for example, a scrap piece of clean cotton cloth).
* Distilled, filtered, or bottled water (tap water may contain
contaminants that can damage the print cartridges).
CAUTION: Be careful not to get ink on hands or clothing.
To clean the cartridge contacts inside the product, follow these steps:
1. Turn on the unit.
2. Open the top cover or cartridge access door.
5. Using a cotton swab or cloth lightly moistened with distilled,
filtered, or bottled water, clean the electrical contacts of the
print carriage.
6. On models equipped with locking latches, lower the latches.
7. Wait five to ten minutes for the contacts to dry and then plug in
the power cord. The unit will begin to reinitialize. Wait until
the process is complete before proceeding.
8. Reinsert the print cartridges when prompted and then close the top
cover or access door.
9. If the message recurs, replace the print cartridge indicated by the
message.
* If you are using refilled or remanufactured cartridges or non-HP
cartridges, replace them with new HP cartridges. HP cannot
guarantee that refilled or non-HP cartridges will function
correctly in HP products.
10. If the problem still exists, replace both print cartridges. Since
the cartridges are electronically connected through the printed
circuit board, the cartridge not indicated in the message might be
the causing the failure.
If the issue still persists, please click on the link below and install
the firmware update:
ftp://ftp.hp.com/pub/softlib/software3/COL4415/oj-14700-3/HpAiOFWUpdate2_2.exe
NOTE: Clicking the link may give an error indicating it is
invalid. If this occurs, copy the portion of the address
on the remaining line(s) and paste it at the end of the
address showing in your browser until the complete address
is displayed in the Address box.
1. Download the file "HpAiOFWUpdate2_2.exe" to a local hard drive. Make
note where (in which folder) the file gets copied.
2. The hp all-in-one software for the OfficeJet 6100 series must be
installed on your PC before installing this firmware update. The
OfficeJet 6100 series must also be connected to your PC and turned on
before proceeding.
3. Locate the file "HpAiOFWUpdate2_2" on your hard drive and
double-click the file to install the firmware update.
This should resolve the issue. If you need further assistance, please
reply to this message and we will be happy to assist you further.
You may receive an e-mail survey regarding your e-mail support
experience. We would appreciate your feedback.
Please visit our Owner Services Web site for details on keeping your HP
and Compaq products up and running.
http://www.hp.com/home/ownerservices
I hope this helps
Mike
Jun 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Mar 27, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
Print cartridge in right stall not supported.
As a refiller, I've seen this many times. Usually it happens in the multifunction machines. If you put that cartridge in a stand alone printer, it will work good. HP all in ones blow a resistor in the cartridge making it useless to any all in one machine. Sadly, it is time to buy new.
Mar 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
HP PSC 2175 All-In-One InkJet Printer Logo
104 people viewed this question
Seeker5211
Seeker5211
