Question about Indesit Washing Machines
Doorlight is flashing will not start(door is closed wright)
  • 784 Answers
There is a micro switch that tells the machine that the door is closed -- sounds like your switch is bad. ( could just be a loose wire ? ) --
c...
Posted on Dec 29, 2010
Interior doorlights blink
The door switch is making intermittent contact. Clean or replace.
Dec 07, 2015 | Kenmore Refrigerators
Why wright pneumatic door closer v150 slams closed
Adjust the speed. Adjudsting screw in the end of it (on the door edn). Tun it in to slow down, out to speed up. Should only need 1 or 2 turns. If still not adjusting, replace the unit.
May 13, 2014 | Wright Products Heavy-Duty Black Pneumatic...
We opened the door, now door won't close. The closer rod is locked open
Turn the screw in the end of the shaft (on the door end) counterclockwise to release all the pressure.Once it closes or slams shut, use that screw to adjust the closing speed. Other problem could be the stay open lock (the metal piece that slides along the shaft) could be all the way out keeping the door from closing. If it is just push on the door a bit then slide the lock plate all the way back to the end of the shaft, and the door will close.
Dec 21, 2013 | Wright Products Tap-N-Go White Screen and...
Can not adjust closing pressure to latch storm door when main door is closed.
Good and Bad
Good, you have a great seal.
Bad, creates pressure not allowing air the escape.
Adjust with main door open and most times screen will close after a long time.
Nov 04, 2013 | Wright Products Tap-N-Go White Screen and...
I have an 01 honda accord and the battery light the doorlight and brake light are all flashing what can cause that
I have a 1998 Honda Accord 4cyl vtec that is doing the same thing but only when its cold. Once the car warms up the lights stop flashing. When this does happen the wipes are slow, light the alternator isn't charging properly. This isn't a service light issue. I know how to reset this light. Lights on the dash that flash are the battery light, the door open indicator lights on the dash and the brake light - all at the same time. I had the battery replaced since mine was two years old but this didn't fix it.
Aug 02, 2012 | 2001 Honda Accord
My fridge is not cold enough. Is it because the doorlight is not working. How can I get the fridge working.
no it is not because of a door light.it is because the thermostst may be faulty
Dec 12, 2010 | Refrigerators
Start/stop light flashing Dryer will not start
the flashing light indicates that the door is not closing
it may be closed by the door switch is not operating properly telling the control it is closed
Oct 13, 2009 | Miele T8005 Tumble Dryer
Door opens and then closes wright away
I figured out that when I replaced the gears, I damaged the RPM sensor. It was easy to swap out the old for the new and now it works fine.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
