Question about Nokia N95 Cellular Phone
Network weak problem - Nokia N95 Cellular Phone
Cell phone doesnt get any service.weak or no signal cant make calls.what do i do?
Try change other simcard and check signal is weak or good?
If still weak no signal maybe your network ic inside phone problem.try restart ur phone
Jun 18, 2017 | Cell Phones
No network problem
Did You try with any other active SIM in the same mobile phone? If the network is still weak Then there must be a signal problem in your mobile phone.
Oct 30, 2012 | Cell Phones
On receiving,or calling phone network goes weak
tell me which phone you have ???
Oct 07, 2012 | O2 02 Mwg AtV
1108 signal problem
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jul 29, 2012 | Cell Phones
Have a weak singla in my home why?
there can be many reasons your signal is weak if you have a lot of devices around the house that use the same frequency i.e. cordless phone, microwave, other wireless networks running on the same channel as yours then the signal will be weaker, also depending on whats between you and the router will affect the speed and strength try moving the router to a higher location, or changing the channel that its running on, try and see if you have a lot of other networks in the area and what channels theirs are running on and select a channel that's not in use if possible. :) hope this helps
Oct 13, 2009 | Linksys WRT160N Wireless Router
My nokia n70 phone weak of signal
hi im josh in cebu phils.friend may i help you? your problem is weak signal. friend when the phone is weak signal there maybe a problem in hardware of the phone. the frequency reciever is weak im sure.but you can boost its functions throught entering the setting and go to network settings and select manual search.your phone frequency will search the network connections around so the hardware will be force to boost.once it will show the network providers around you select the network you are using and it will be setted to the network in more/ higher frquencyh signal. thats all friend hope i helped you.good luck/
Feb 28, 2009 | Nokia N70 Cellular Phone
Computer will not connect to wireless router
the antenna wire sounds pinched it is in the usually in the lid and can be found by looking in the hinge area
Look to see if it is kinked
LB
Sep 21, 2008 | ASUS Eee PC 900 16G Notebook
Check the wireless network card
try to reinstall the driver
Jul 27, 2008 | Computers & Internet
I'm getting a weak signal from my PS3 on my wireless network. My laptop works great on the wireless network. Advice?
Hi Samax,
I have noticed that Routers sometimes give a better signal to my neighbors than it does me in the next room. Try opening your router config screen, and setting its output to a lower DB.
Nov 09, 2007 | Sony Playstation 3 (PS3) Console
Nokia N95 Cellular Phone Logo
77 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
