Fan motor is making a noise - Heating & Cooling
  • 784 Answers
Could be the fan motor bearing or something like dirt/dust build up around the fan itself. open up the unit to expose the fan and check for dirt and dust,, if all looks clean -- drip some tool oil on the fan motor bearing and that should solve that crazy noise.
c...
Posted on Dec 29, 2010
My whirlpool side by side fridge/freezer is making a loud noise while running.
If the noise is coming from inside, the evaporator fan motor (the fan motor that circulates cool air located in the freezer section) may be the culprit. If noise is on the outside, the condenser fan motor may be the problem. This is the fan motor that removes the heat from the refrigerator to the room.
Jun 14, 2015 | Whirlpool Refrigerators
Exhaust Fan makes noise
Check to make sure that nothing is obstructing the fan blade causing the noise, if not then the bearings in the fan motor are more than likely going out causing the metal on metal noise.
Apr 24, 2012 | GE Microwave Ovens
Honda pilot 2007 blower fan making noise blower fan was replaced once still making noise
Either its developed the same fault or the fan motor bearing has failed, needs greasing or, if there's a belt, the belt is slipping.
Feb 22, 2012 | 2008 Honda Pilot
Noise some times and fans dont work some times
99 out of a hundred times - when the fan motor on a window unit 'makes noise and works intermittedly,' you have a bad fan motor which will require replacing.
Sounds as if the fan motor's bearings are making noise - which - would account for the fan working only part time. The reason being is that the 'bearing noise' you are hearing - is a result of the bearings being wore out - thus it causes the fan motor to heat up and 'go off' - on the internal overload' which is built into the fan motor.
Like I said above - most commonly the 'fix' is to replace the motor.
Jun 09, 2011 | Frigidaire FAC106P1A Thru-Wall/Window Air...
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Noise from the fan/fan motor
The bushings in the motor are worn out, replace motor. This should correct the problem.
Sep 10, 2009 | Refrigerators
Noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
May 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Showcase freezer fan motor makes constant clicking noise
Is the noise clicking consistantly?or just on again off again?Yes there may be a faulty motor.Try removing the wires and tape them up then run the unit if there is still noise need more info .And to let you know yes they can be made into a low quality air compressor:) hope i helped :)
May 11, 2009 | Frigidaire FRS26R4A Side by Side...
FAN IN THE FREEZER DEPT MAKING NOISE MAYBE FAN
if the fan is making noise it can also due to dust collected in the fan winks towards it end.or the other option is motor getting weak and needs replacement.
Feb 20, 2009 | Hotpoint HSS25GFP Side by Side...
Heating & Cooling Logo
234 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
