Question about Carrier 36KCARMS Air Conditioner
Hi , my ac indoor turn on and only the fan is blowing but there is no heat nor cold air is on even when i tried to change the temperature from 18 to 30 deegree celsius the compressure not respond, but the red led is flashing at the indoor unit what could probably happen to it,plse
    Problem Solver:
  • 3 Answers
You need to replace the main termis if this is not ya problem then ya fan belt broke mate check then get back to meeeeeee
Posted on Dec 29, 2010
Honeywell TH6320WF when i turn system to heat and fan on auto it says heat on but never clicks on but then when i change fan to on the system clicks on but it seems to be blowing cool air
It sounds like the heat setting is not high enough. The heat setting needs to be higher than the indoor temperature or the fan will just blow non-heated air.
Dec 03, 2016 | Honeywell Heating & Cooling
Heat is not constant. Why won't fan turn on?
Hi Fredy,
If the outdoor temperature is really cold the indoor will cycle on and off - the fan will cycle on and off as the indoor coil heats up - the coil needs to be warm - a sensor detects this and then turns the fan on
Goodluck
Dec 31, 2015 | Heating & Cooling
I have a Frigidaire heat and ac unit. Model FAZ12HR2A. Fan kicks on but has no heat coming out?
Turn your AC on and see if it is blowing cold air. If it isn't, it is most likely the "blower" that has gone out. Also check the thermostat and try putting in new batteries (even if it appears to be working). Another thing to try is to make sure you have changed your filter. A dirty filter can block the air flow.
Nov 14, 2014 | Heating & Cooling
My Mistral MSS25 has stopped blowing hot air, it's only 6 degrees and it's friday afternoon before a long weekend! Is there anything I can do to fix it before someone can come out here next week to lo
No heat pump will put out much, if any at 6 degrees.
A heat pump is an air conditioner that reverses cycle via a reversing valve that re directs the refrigerant flow in the unit, in ac mode,
heat from indoors is rejected outdoors in the heat mode the heat from outdoors is rejected indoors.
The system does this by evaporating and condensing refrigerant.
For the refrigerant to be "boiled" or "change state" from a liquid to a vapor a temperature differential must exist, meaning the heat from the outdoor air must "boil" the liquid refrigerant.
For this to be possible the liquid refrigerant must be colder than the 6 degrees ambient or it will not boil anything.
For a refrigerant used for AC to be that cold the pressure will be in a vacuum for most refrigerants temperature pressure relationship.
Heat pumps below 40 degrees ambient outdoor temperature are
not effective, at this temperature outside drops a degree lower it further degrades the heat output .Power companies that finance Heat pumps typically will install an outdoor thermostat to prohibit the 2nd stage or electric heat strips from coming on until it is 40 or below outdoors, at a certain point well before 6 degrees a heat pump should be ran on the emergency heat mode which is the heat strips and the fan. Since 1500 Watt electric heaters are available at Wal-Mart for $20 the best alternative in this situation would be to buy a few of them.
Jun 06, 2014 | Heating & Cooling
My ac is blowing cool air only, it is at full charge
You need to turn off the button that say AC on it. You need to change the temperature and the fan adjustment. If you have the AC button turned on, the fans will blow cool air even though the heat is turned on.
Apr 17, 2011 | 2000 Jaguar S-Type
Indoor fan blowing cold air when on heating
The indoor fan will continue to run. When heat pump goes into defrost the outdoor fan stops, the reversing valve switches and the unit is basically working in the cooling mode. In order for you not to feel a blast of cold air in the winter the electric strip heat also comes on so the indoor fan must run while the strip heaters are on.
Jun 03, 2010 | Heating & Cooling
1998 Olds Aurora, no heat, no air, just blowing air out the front
i beleive these are a vacuum system. if air temp is in cold position you will get no heat. listen for hissing noise with motor turned off but key on. if you hear hissing noise you have a hose broken or off. you will have to find it
Oct 30, 2009 | 1998 Oldsmobile Aurora
My Blower Turns itself on when it is not supposed to.
If your indoor unit is located in the attic, you may be experiencing the result of a high temperature safety device (possibly too sensitive) that is responding to warm air drifting up the return air duct. The function of this device is to turn on the fan at a given set point and cool the unit back down. Have someone identify your limit rating and change the limit device with one rated the same or see if the maker of the unit has an upgrade/service bulletin on this fault.
May 03, 2008 | Ruud Handler Air Conditioner
Carrier 36KCARMS Air Conditioner Logo
85 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
