Question about Vivitar DVR-560G Camcorder
My vivtar will not come on but i have used it before. It has been dead for a couple of days and i had forgot to charge it but i carged it all night and it wont come on.
I have had my zeepad on the charger for a few days now and it is not fully charged. What do I need to do for it to recharge?
Probably, the ac charger unit isn't good anymore. Output charge voltage& current isn't sufficient to drive your battery charge beyond 80% threshold.
Change or replace this with a new one (same ac charger specs please) and charge your tab again.
Oct 09, 2017 | Tablets & eReaders
Dead phone
I know this sometimes happens with these smart phones; one day they just up and quit.
You could try a fresh battery, and check your charging source.
Mine did something similar a couple days ago - I thought it was charging all night long, and in the morning when I went to turn it on... nothing. It ended up being my charging cable, it wasn't putting any juice to the phone.
Apr 01, 2014 | HTC EVO 4G Smartphone
Battery died but when opened up to check battery there is a ticking sound
Yes one of the relays could be draining the battery.
I would open the fuse and relay boxes and try to find where the noise is coming from. If it is a relay, pull it out and see if the noise stops.
Jan 15, 2013 | 1999 Toyota 4Runner
Battery on huskee 4200 runs dead
is the battery any good they only last a couple years charge it leave one cable off over night then hook it up if is still dead then the battery is no good if is good to go then check for a draw most auto parts stores will test it for free but charge it before you bring it there
Apr 28, 2012 | Garden
When i charge my battery its all full bars i hold the phone in my pocket whole day (its still fully charge) when i got to bed at night and wake up in the morning the bettery is (half way) i hold the phone...
Depends on whats running and what you use it for during its use. Technically shutting it off to reset it once a day is good, but it being half dead a day and half later is pretty normal
Sep 26, 2009 | Samsung Eternity Cell Phone
Bikes dead!! Battery wont charge, been charging all night Help!
You didn't mention if you charged the battery in- or out of the bike. If H-D has a modern alternator, it may have failed diodes that are draining the battery and stealing charge current if charged while connected. If the battery was made in China . . . oh, well.
Jul 01, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
2001 vw beetle after charging the battery over night it will not
Try jumpstarting from another car. You probably did not get the battery fully charged before you tried it. Also, check to see if the cables are connected tightly and if they are corroded, clean them before doing anything else. When you jump start, make sure the cables go on the correct terminals at both ends. Make the last connection to the ground on the bug (- wire)
Feb 15, 2009 | 2001 Volkswagen Beetle
Motorola v220
not really you need to have the microphone check on the phone it could need replacing or servicing so take it to a mobile technician to hvae it fix.
May 26, 2007 | Motorola Mobility V220
Vivitar DVR-560G Camcorder Logo
27 people viewed this question
Top Vivitar Video Cameras Experts
Joseph Wright
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
